Durametric diagnostic software and cable kit
Old Mar 24, 2009 | 02:15 PM
Md11skipper's Avatar
Md11skipper is just really niceMd11skipper is just really niceMd11skipper is just really niceMd11skipper is just really nice
I have purchased a Durametric software kit (software and cable) and I am very happy I did. It enabled me to not only clear fault codes I had received while doing a dyno run but also (most importantly) check the history on ignition counts in the different rpm ranges from the previous owner. It is really easy to use and works wonderfully. I also liked to see the total hours the car was used, I divided those hours with the mileage the car has and came up with an average speed of 28 miles per hour spread over the 8000 miles the car has now. Average is about 35 according to Durametric hence my car was driven conservatively add to that few ignition cycles above 7000 rpm and I feel confident to have purchased a car with a great engine!
When I wanted to update the firmware of the cable, I must have screwed it up and the cable stopped working. I called tech support from Durametric and got Duram on the phone, what a great man! He is very friendly and supportive, he helped me through the steps to manually update the firmware (because I screwed up the autoupdate) and now it is working again. Not only is the product great but the tech - customer support is excellent!
Great product!
Old Mar 24, 2009 | 11:32 PM
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
+1
Duram is super cool and answer my many question through e-mail. I heard they will update the Porsche software soon with added features. I have not used the RPM and ignition count etc. Just used the software to clear error codes such as airbag warning light and such
Old Mar 25, 2009 | 01:11 PM
Durametric
Mikymu,
I bought the software due to your last write up, thanks for the heads up!
Using the ignition counts in the 6 different rpm ranges is very easy to do, give it try, its also the place where you find the total hours as well as other useful info. Good to know esp. if you bought the car used.
Originally Posted by mikymu
+1
Old Mar 25, 2009 | 05:15 PM
mikymu's Avatar
Originally Posted by Md11skipper
Mikymu,
Glad you like the software. Will give this RPM range thing a try
Serg124
Sep 10, 2015 05:27 AM
orbelo
Aug 30, 2015 12:26 PM
oddjob142
Aug 24, 2015 05:49 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
Aug 19, 2015 06:55 PM
