You guys with centerlocks need to get your nuts torqued!!!
Old May 18, 2011 | 08:43 AM
  #46
cc08gt2's Avatar
cc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud ofcc08gt2 has much to be proud of
^Yeah. I've had that too. I think that's why they changed the spec again. If the spring is not all the way out, you can have trouble. To this day not many techs know about this problem or pay attention. It's not fully engaged unless the spring is fully out.
Old May 18, 2011 | 11:12 AM
  #47
BigDaddyM's Avatar
BigDaddyM is infamous around these parts
Thumbs up
Originally Posted by Davidham
Makensure that the spring loaded locking nut is out after you torque down. I had mine loosen up after 4 laps!!!! FYI, car does not drive well with loose nuts!!! One of the rear nuts won't stay tight, so I have a new one coming! I love these center locks!!!
No issie with the nuts yet but i'll keep an eye out. I'll run it this weekend at Spring Mountain
Old Jun 11, 2011 | 09:47 AM
  #48
Big Al's Avatar
Big Al has a spectacular aura aboutBig Al has a spectacular aura aboutBig Al has a spectacular aura about
Center locking Pin
Page 3 and 4 of the center locking instructions talks about the center spring that need to be flush. For the life of me i can't get the spring to pop out so its flush. If i loosen it enough so that I can trun it by hand to the left and then to the right it will pop out. But then when I torque it, it goes back in and won't pop out. Any suggestions?
Old Jun 11, 2011 | 09:56 AM
  #49
cc08gt2's Avatar
Continue to slightly tighten a bit. I've had hell with that deal too. But, unless it's FLUSH, it ain't right.
Old Jun 11, 2011 | 11:49 AM
  #50
TRAKCAR's Avatar
TRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of light
Just screw a bolt in the center, tighten it and back it off, with a wiggle.
Old Jun 11, 2011 | 03:27 PM
  #51
Big Al's Avatar
Guys I got it! I followed the tightening procedure to a tee and it's flush. It said tighten it to the torque spec of 444, then loosen it 1/6 of turn and then back to 444 and it pops out flush every time.
Old Jun 11, 2011 | 03:43 PM
  #52
TRAKCAR's Avatar
You just got lucky........
Old Jun 11, 2011 | 03:51 PM
  #53
Big Al's Avatar
I'll take all the luck I can get. But I tried on all 4 wheels several times and it work. Its just like if you losoen it to the point where you can use your hand turn it left and then right and it pops. Try it and let me know. But in case it was luck what do you mean by screw in a bolt and then back off with a wiggle???...which bolt do u mean the center lock???
Old Jun 11, 2011 | 08:43 PM
  #54
pfan12000's Avatar
pfan12000 is infamous around these partspfan12000 is infamous around these parts
The trick is explained in the TB Porsche sent out. All you need to do to get the spring lock to pop out flush is to insert the square drive of the breaker bar 3/4" drive into the spline area and twist until the spring mechanism pops out flush. Please award me some rep points if you like this suggestion.
Old Jun 13, 2011 | 08:35 AM
  #55
brownan's Avatar
brownan is a jewel in the roughbrownan is a jewel in the roughbrownan is a jewel in the rough
That's what I do...stick a 3/4" drive in there and give it a little wiggle. Spring lock pops out every time.
Old Jun 15, 2011 | 07:47 AM
  #56
Croc-ket Man's Avatar
Croc-ket Man is infamous around these parts
Procedure change?
I have heard that this torquing spec has been rescinded by Porsche. Is that true?
Old Jun 15, 2011 | 08:12 AM
  #57
Big Al's Avatar
I have not heard that. But will call me dealer.
Old Jun 16, 2011 | 10:20 AM
  #58
drdrilz's Avatar
drdrilz is a jewel in the roughdrdrilz is a jewel in the roughdrdrilz is a jewel in the rough
Old Jun 16, 2011 | 10:23 AM
  #59
cc08gt2's Avatar
Holy HELL, Batman.
Old Jun 16, 2011 | 11:06 AM
  #60
Big Al's Avatar
I just called Porshce gave them my vin and was notified that as of May 6, 2011 there is an open recall relating to the center lock and hub. Its open recall number AB01.
