Lots of smoke cold start 3.6 GT3RS
Old Jan 8, 2012 | 06:49 PM
335_II's Avatar
335_II is infamous around these parts
Everytime i start my RS cold it smokes white a good amount. It would usually do this only when the car would sit. Now it does it even if I drive it daily. Any ideas on what it could be?
Old Jan 8, 2012 | 07:15 PM
Glock Guru's Avatar
Glock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to behold
If its bad every day, time to call Alex @ SW and upgrade to a 3.9L
-Troy
Old Jan 8, 2012 | 07:44 PM
snowboarder54's Avatar
snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !
What Troy says! it's the only solution!
Old Jan 8, 2012 | 09:22 PM
bli8's Avatar
bli8 is infamous around these partsbli8 is infamous around these parts
My 996 GT3 and 997 TT both blew white smoke when starting cold. I think this is quite normal. Something to do with horizontal opposed cylinder heads leaving oil somewhere that gets burned off upon cold starts. Do a search on the forum on related threads.
Old Jan 8, 2012 | 10:11 PM
KYROCKS's Avatar
KYROCKS is infamous around these parts
Sounds normal. I found if you let the car idle for about a minute before you shut it off, the smoke is gone or minimal next time you start it.
Old Jan 9, 2012 | 03:21 AM
mikegr's Avatar
mikegr is infamous around these parts
Yes, it is wise to leave it on, for a couple of minutes even if it is not a Turbo version
Old Jan 9, 2012 | 04:04 AM
evil panda's Avatar
evil panda is a splendid one to beholdevil panda is a splendid one to beholdevil panda is a splendid one to beholdevil panda is a splendid one to beholdevil panda is a splendid one to beholdevil panda is a splendid one to behold
yup, happens to me too. although mine does it more randomly than yours. I just make sure there's no one walking behind when I start the car, especially in places like the office where I'm likely to know the person I just gave a face full of smoke to
Old Jan 9, 2012 | 12:11 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
A good description why the 997tt smokes during start- https://www.6speedonline.com/forums/...4-seconds.html
Old Jan 10, 2012 | 09:20 PM
LFC911Kop2's Avatar
LFC911Kop2 is infamous around these parts
Yes very normal on my RS too. Nothing to worry about. It goes away quickly. People that see it say it looks cool. Doesn't bother me! She's an amazing engine!
Old Jan 10, 2012 | 09:59 PM
lopro's Avatar
lopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to behold
ive noticed this also. Good to know more about it. let her run a moment before shutdown
Old Jan 11, 2012 | 03:06 PM
jbryan's Avatar
jbryan is infamous around these parts
I think a lot of smoke on start up every time is a sign something is not right. I know of many GT-3's, including my own, that very,very rarely smoke and then it is barely noticeable.
Old Jan 12, 2012 | 08:05 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
I do not know about the rest of you...but my car when it does smoke leaves the strangest smell in the garage, unlike any other pcar I have owned....must be that it needs a 3.9
Old Jan 12, 2012 | 10:05 AM
MTV's Avatar
MTV
MTV is just really niceMTV is just really niceMTV is just really niceMTV is just really niceMTV is just really nice
Completely normal bud.
It'll be a lot more frequent when tracking/beating on the car and letting it sit for a few days.
Old Jan 12, 2012 | 02:37 PM
Tim Kay's Avatar
Tim Kay is infamous around these parts
Normal, and idle before shut down helps.
I have also got in the habit of, during and after the idle time, not pressing the brake pedal after the motor stops, only use the e-brake. I read here once that depressing the brake right after the motor stops releases any vacumn from the motor.
The theory is a bit of vacumn won't let oil by the RMS and the hot oil around the RMS is given time to "clear" away from the seal area. By the time the vacumn has reduced to nothing there is minimal oil to exit the RMS. Seems to work for me.
Old Jan 12, 2012 | 02:45 PM
Rental Metard's Avatar
Rental Metard has a spectacular aura aboutRental Metard has a spectacular aura aboutRental Metard has a spectacular aura about
Both of my Turbos and my Boxster all did this. I've been told switching from 0W-40 to 5W-40 improves it dramatically. I plan to switch on my next change.
