Airbag light after roll bar install
Old Apr 23, 2012 | 05:35 PM
mplatt911's Avatar
mplatt911 is infamous around these parts
I spent a day taking out my seats and installing a tequipment roll bar in my 2005 GT3. Unplugged my seat belt plugs in rear panels also. Got everything reinstalled and realized battery went dead from doors being kep open so long. Airbag failure light is on. Am I doomed to try and find a dealer to reset and check for faults. I've got no one around for hours.
Mike
North Country New York
Old Apr 23, 2012 | 06:52 PM
DHI's Avatar
DHI
DHI is a jewel in the roughDHI is a jewel in the roughDHI is a jewel in the rough
Reset at dealers required.
Not a big deal other than the drive you face. Will take all of 10 minutes.
You can also invest a couple of hundred to buy your own Durametric instead. Push come to shove, ask if someone has one in you area.
Old Apr 23, 2012 | 06:55 PM
LTCJMRamos's Avatar
LTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud of
And/or remove/reinstall the seats to make sure all connections are made.
Old Apr 24, 2012 | 06:45 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Rule of thumb when removing or disconnecting ANY airbag connection: disconnect the battery. If you don't, this will happen. Your seats have torax airbags...
Old Apr 24, 2012 | 08:29 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
this seems to work for some (most?) people but not others...me, for instance! anyway, i had a bud with a durametric who helped me out.
hey, OP, is it your center console ("passenger airbag off") light? or the dashboard red airbag light? FYI, my center console light could NOT simply be cleared with a duramet/PIWIS. i went from stock seats to the GT2 buckets and even tho i cleared the fault, the center console light stayed on. it seems that sometimes the AWS needs to be recalibrated. until then, the light will stay on / the bags will be inactive because the ECU cant detect passenger seat weight. only a PIWIS can do this calibration. however, you can trick the system cheaply by using a duramet to turn off the AWS feature - the ECU will no longer be analyzing the weight of the seat thus the bags will be active all the time.
good luck
Old Apr 24, 2012 | 08:27 PM
mplatt911's Avatar
It only has the red airbag failure message on the display screen and the red light stays on in the dash . Sounds like I need to spring for the dura metric , which I can use on my cayenne tt for also. Next time I'll be disconnecting the battery . Thanks for the replies
Old Apr 25, 2012 | 09:48 AM
JoelPirela's Avatar
I had disconnected the seats, door airbags and steering wheel's airbag with no problem, as long as I disconnect the ground from the battery first.
Old Apr 25, 2012 | 08:07 PM
DHI's Avatar
DHI
Hey!
I just found a cheaper solution for you... a Porsche PIWIS cable on EeBay... 49$.
I am considering buying one, just in case.
Several appear to have used the cable in question successfully.
Cheers!
Old Apr 26, 2012 | 01:15 PM
techart996's Avatar
techart996 is infamous around these parts
any Porsche independents in your area ? they should have the machine as well
The_Ruski_Driver
Oct 25, 2015 08:40 PM
no1joey
Sep 2, 2015 12:32 AM
TrackOne
Aug 20, 2015 12:56 PM
Walorus
Aug 18, 2015 01:39 PM
