GT2 brakes on the track
Old Jun 13, 2006 | 09:45 PM
yellow's Avatar
yellow is infamous around these parts
Those of you who are running PCCB brakes on the track what are you guys doing. Are some people switching over to steel brakes? If so what are you guys using? Will i feel a big difference if i covert over to steel brakes? Where do you usually buy your brake parts from?
Old Jun 13, 2006 | 11:36 PM
supercup's Avatar
supercup is infamous around these parts
I have converted to steel brakes. I took off the stock PCCB and calipers and replaced with Factory Cup Car brakes (996). Take a look at Grussell's posts on what he has done. He has recently added big Brembo's - they are awesome!
https://www.6speedonline.com/forums/...t=50079&page=3
JCM
Old Jun 14, 2006 | 12:09 AM
yellow's Avatar
im looking at different options to see what is more cost effective. I would rather not change calipers since cost is quite a bit in doing that. What are some options or is better just to keep it stock?
Old Jun 14, 2006 | 01:46 AM
jay_ftw's Avatar
jay_ftw is infamous around these parts
Are the PCCB's just not up to par? I know they're an $8k option on the 997's...Why are people changing them out?
03-turbo911's Avatar
Senior Member
You don't have to change calipers if you go with the steel cup rotors and the rear 997 GT3 rotors. They fit like a charm on your PCCB calipers.
Old Jun 14, 2006 | 08:53 AM
cgmeredithjr's Avatar
cgmeredithjr is infamous around these parts
Replace your stock pads with Pagid RS-19 endurance racing pads and change your brake fluid to Castrol SRF...that's all you have to do. I have almost 18,000 miles on my GT2 and approximately 15 track days...I do not drive the car slowly. Front rotors are starting to show some wear, but are still working fine, rear rotors still look new. My first set of RS-19 front pads lasted approximately 13,000 miles...the rears have been on the car for 16,500 miles and are about 50%. The only negative to these pads is that they do squeak on the street, but they work great on the track...the hotter they get, the better they stick. I think the pads are about $700/set and the fluid is pricey, around $75/QT. Call Bob Sanderson at Kinetic Speed Shop: 770-271-1577
Cleve
Old Jun 14, 2006 | 12:16 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
The PCCB is decent on track and superb on the street. Depends on how much money you want to spend. The Brembo GTR is the best but cost $12K. I replace the front rotors with Supercup Disk w/ Hat( AP 350x33, slotted) and rear with GT2 AP rear disk conversion (AP 350x28). And Pagid RS29 Yellow Pads. Reuse stock calibers. $4K parts and labor.
Very little squeaking on the street but a lot better then PCCB on the track.
Old Jun 14, 2006 | 01:06 PM
yellow's Avatar
I dont want to loose performance, and the PCCB brakes are ok but i have heard it gets expensive using them on the track. I plan to 30 or so DE's this year and want to do it without spending a ton on brakes. Since im not racing i dont need the best braking system out there. Just want to do something where i dont loose braking performance and use a system which is cost effective. Out of the two options i have heard could i change the front rotors to steel and use a black pagid as i did in my turbo? And the rear just change to the same pad and leave the stock rotor and caliper? I need to change my front rotors since its starting to show wear. Thanks for all your help guys!
Old Jun 20, 2006 | 11:38 AM
steve-d's Avatar
steve-d is infamous around these parts
Replacing front rotors
.... Out of the two options i have heard could i change the front rotors to steel and use a black pagid as i did in my turbo? And the rear just change to the same pad and leave the stock rotor and caliper? I need to change my front rotors since its starting to show wear. Thanks for all your help guys!
Try Suncoast. They have direct replacement GT 2/3 performance rotors. Floating rotor design, aluminum hat and NAS fasteners. They are OE dimension and don't require any replacing of calipers at all. They'd save a ton of weight too vs the OE one piece rotors.
With the $4k cost quoted for the other you'd save 40-45%. Put it toward a set of track tires!!
As you're not changing the calipers, you can use the specified pads or any other you choose. Race pads are such a personal choice with so many manufacturers out there.
Give Phil Anderson a call and he can guide you 887 923 1700
Old Jun 20, 2006 | 11:41 AM
LUISGT3's Avatar
Yellow,
PM sent.
Old Jun 21, 2006 | 12:42 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Our Gt2 runs stock PCCB rotors and Pagid pads- And the car is tracked often.
Cup Car rotors will bolt up - Supercup has them on his car and likes them.
We havent had any problems with ours- although the stock pads will fall apart and squeel like little piggy's -
Flush with SRF - bleed the ABS pump too... And install some Steel braided lines- Your set..
Pagid pads are probably the most friendly to the PCCB rotors- PFC or anything else will most likely destroy the rotors.
Old Jun 21, 2006 | 07:34 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
With the proliferation of PCCB across the Porsche model line, I think it's very possible that the price of the replacement rotors will continue to come down. They used to be about $8K per corner, now they are $2K. If they get down to about $1K per corner, they will indeed be a very cost-effective solution even for the track... as they last at least 3 times longer.
Only reason why people ***** about PCCB is that the rotors are very expensive. If price was no object, I really doubt most people would change them out. Porsche even uses them on the new Cup car! Less unsprung weight, great initial bite, and doesn't fade... they really are wonderful brakes, and much better than the steel ones.
Old Jun 22, 2006 | 12:54 AM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
here is a set if pccb rotors after 2 track day and about 10k miles
pccb
steel conversion percormance friction rotors pf97 pads
Boris
Old Jun 22, 2006 | 12:56 PM
yellow's Avatar
The problem that i have had with the ceramic brakes are that the pad lasts only 2 days of DE at the most. So i put in the yellow pagid RS19 pads in. Now i just have to change out the rotors. Going to work on locating what parts work for that today
Old Jun 22, 2006 | 03:12 PM
NMEX's Avatar
NMEX is infamous around these parts
I dont know guys. I have a GT3 with PCCB and so far 10 DE and street driving. My set of RS-19 still more that 50% and NO CRACKS AT ALL . Changing to still will change your Geaometry on Braking since you have more weight. ( Then again dont know how hard you drive) After almost a full year of track use I will consider trying to buy a used PCCB set and save as spare and use yours.
Jul 29, 2019 11:13 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
TrackOne
Aug 20, 2015 12:56 PM
