Panamera Oil Change DIY
Old Oct 10, 2015 | 07:41 PM
  #31
cheetos72's Avatar
cheetos72 is infamous around these parts
I looked at Oil-filter cover to oil guide housing, not the lid on oil filter housing.
Old Oct 24, 2015 | 07:53 PM
  #32
cheetos72's Avatar
FYI I did the work today and I measured 19.1 ft/lbs on my snapon tools torque wrench while taking the oil filter cover off. The dealer did the last change. Hopefully this helps.
Old Oct 25, 2015 | 09:44 AM
  #33
aldous's Avatar
aldous is infamous around these parts
Thanks a lot! That's great help. I agree 19 ft lbl should be enough for oil filter cover.
Old Oct 28, 2015 | 10:46 PM
  #34
cheetos72's Avatar
Glad to help and to get this documented. Also I noted the bolts in the aluminum frame you can remove to get to the oil filter were torqued at 18-20ft/lbs (measured)
Old Jun 12, 2016 | 04:52 PM
  #35
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Originally Posted by litumup411
Just changed the oil. As previously mentioned the panel underneath needs to be removed (21 torx type screws). I have a Skil drilldriver and retorqued them to the 11 setting. Figured this out by ramping up the torque as I removed them. Started at 5, then 7,9, etc. 11 removed it, so I tightened them at 11. Didn't want to strip the threads.
You'll need an 8mm allen wrench to loosen the drain plug.
The filter is closest to the front passenger side. A standard 36mm socket wont remove the filter housing. Too deep. You'll need a shallow 6pt. Available from Sears German-made:
http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
How many inches do you have to get a socket in? I have (not a deep) 36mm socket I used on my 997. I m asking about a v6 non turbo.
Old Jun 12, 2016 | 06:06 PM
  #36
cerbomark's Avatar
just checked and I can reach it from the top with lots of room for any 36 mm socket on a v6 non turbo. Maybe the v8 s are tighter.
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
Jaytaylor10485
Aug 28, 2015 06:25 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
