LED interior light kit
Old Sep 14, 2012 | 03:16 PM
  #31
TGED's Avatar
TGED is infamous around these parts
Thanks.
Old Jul 14, 2013 | 11:30 PM
  #32
stanleychien's Avatar
stanleychien is infamous around these parts
Any update on this? Any pictures?
Thanks.
Old Jul 15, 2013 | 06:54 AM
  #33
TGED's Avatar
I changed the interior lights to LEDs, footwell lights, door edge lights, trund lid, trunk compartment, very easy to do. Since the lower console LED is so un-noticeable, I will not bother.
Old Jul 25, 2013 | 12:54 PM
  #34
bhnguyen92117's Avatar
bhnguyen92117 has a spectacular aura aboutbhnguyen92117 has a spectacular aura about
Please post pictures.
Old Jul 25, 2013 | 03:38 PM
  #35
TGED's Avatar
I changed 4 footwell, 4 door edge, 2 trunk lid edge, 2 trunk interior, total cost was about $60. I will post pics later, very easy to do, took less than 10 mins.
Old Jul 25, 2013 | 03:46 PM
  #36
TGED's Avatar
If you have money to burn, you can spend $1000 to get the optional factory extended LED package, the only difference is you get the lower console LED strips which are so dim that they are barely noticeable. I could also change the sun visor mirror to LEDs but I chose not to as I prefer facial color under incandescent light which looks more natural.
Old Jul 25, 2013 | 05:00 PM
  #37
I don't have enough posts yet to PM you about where you got the LED lights so could you PM me with that info? Thanks in advance.
Old Jul 25, 2013 | 08:22 PM
  #38
TGED's Avatar
These are what I use for footwell, door edge, and trunk compartment.
Old Jul 25, 2013 | 08:25 PM
  #39
TGED's Avatar
And these ones for trunk lid edge, because the other ones which I prefer, as they have LED bulbs on the sides and at the end, are slightly too long.
Old Jul 25, 2013 | 08:30 PM
  #40
TGED's Avatar
I bought the LED bulbs from a local auto gadget store in Toronto. As you are from San Diego, there is no use for me to tell you where I bought mine from. These bulbs are fairly common and should be easy to get.
Old Jul 25, 2013 | 08:36 PM
  #41
TGED's Avatar
This shows the door edge and footwell LED.
Old Jul 26, 2013 | 10:35 AM
  #42
Thanks for the info. I know where to get these.
Old Jul 26, 2013 | 06:16 PM
  #43
TGED's Avatar
I just noticed we have the same model year Panamera 4 and mine is white also.
Old Dec 1, 2013 | 01:11 PM
  #44
Gdioguardi's Avatar
Gdioguardi is infamous around these parts
Any one knows how to open up the dome light to replace the bulbs for led lights?
Old Sep 17, 2014 | 09:52 PM
  #45
cheetos72's Avatar
cheetos72 is infamous around these parts
I know this is an old posting, but I wish I had the following information when I worked on the lights:
Using a plastic trim tool pry the trim off starting from the front and working your way back. Then with the same trim tool start removing the dome from the front until it "stops" then about 1/2 inch to 1 inch back there are clips on both sides. Push in there with the trim tool to release. There are more clips further back that I was unable to release.
I used the space that was opened to change the bulbs without fully releasing. Removing the bulbs was difficult as the turning action was difficult - I used a cloth to protect my tender fingers . Simply remove the bulbs and replace with your replacement LEDs.
Afterwards pop the dome light area back up and then re-attach the trip STARTING FROM THE REAR of the light (near the mirror).
I hope this helps
