Horn problems
Old Jun 6, 2013 | 04:38 AM
Leslierc's Avatar
Leslierc is a jewel in the roughLeslierc is a jewel in the roughLeslierc is a jewel in the rough
Horn problems
Hopefully it won't be a big deal to fix, but I noticed this morning that my horn isn't working. Has anyone else here experienced problems with the horn in their Panameras?
Old Jun 6, 2013 | 06:11 AM
MIA997TTBeast's Avatar
MIA997TTBeast is infamous around these partsMIA997TTBeast is infamous around these parts
Have you checked the fuse? Get the Owners Manual and see if it needs replacement?
Old Jun 6, 2013 | 08:31 AM
donfenn's Avatar
donfenn is infamous around these parts
I had a very weak anemic horn on my Panamera... Dealer fixed it.. It was listed as remove and reinstall on the service invoice.. I had a loaner with the same problem and mentioned it to service writer when I returned it... They told me its not uncommon, but easily fixed..
Old Jun 6, 2013 | 09:23 AM
Leslierc's Avatar
Thanks! I phoned the dealer this morning and made an appointment for next week. It seemed to me that the horn had been sounding weaker even though the statement from the recent 10K service said that the horn had checked-out fine. It's under warranty, so I'll let the dealer handle it.
Old Jun 6, 2013 | 03:32 PM
hummerchine's Avatar
hummerchine is infamous around these parts
Interesting...my horn is kinda embarrassing, my wife makes fun of it.
I'll see if the dealer can make it better!
Old Jun 6, 2013 | 04:08 PM
Root's Avatar
Root is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of light
Great you guys are using your horns to tell the slowbies to move over
Old Jun 6, 2013 | 04:33 PM
DMoore's Avatar
DMoore is a jewel in the roughDMoore is a jewel in the roughDMoore is a jewel in the roughDMoore is a jewel in the rough
I had the horn replaced in my '10 P4S quite some time ago. I had no idea of a problem until some bozo cut me off -- and I could barely hear my own horn! No way could he/she/it have heard me.
Dealer replaced horn without any issue and the problem was solved. Come to think of it, my new P-GTS is only a week old and I haven't touched the horn yet. I'd better honk it on the way home tonight to make sure it's OK!
DMoore
'13 Panamera GTS
'13 Carrera S
Old Jun 7, 2013 | 04:12 AM
Leslierc's Avatar
I flash my high beams for that!
Actually, I find that other drivers often don't see me because of the car's low profile and it's been my experience to use the horn to warn other drivers from drifting into my lane.
Old Jun 12, 2013 | 10:32 PM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
dealer is fixing my horn under warranty
Old Jun 13, 2013 | 03:49 AM
Leslierc's Avatar
The car is scheduled with the dealer tomorrow and I'll update after that.
Old Jun 14, 2013 | 03:18 PM
Leslierc's Avatar
So, I've now learned that the system consists of 2 horns - a low note horn and a high note horn. Apparently, after diagnostics and replacing the fuselink, both were found to be defective on my 4S. The dealer had a low note horn in stock and they installed that and ordered a high note horn. They will schedule me when that item arrives. I'll say this, the low note horn is plenty loud!
Old Apr 12, 2017 | 03:25 PM
striped91's Avatar
striped91 is infamous around these parts
So, does anyone have any real information regarding the weak/no horn issue that doesn't include having a Porsche service department just replacing parts? It would be nice to hear from someone that does their own work, and actually know something about the repair.
Old Apr 16, 2017 | 04:54 PM
striped91's Avatar
Never mind...I figured it out. I replaced the cheap OEM horns with Hella Super Tones. Since the current provided by the horn switch at the horn electrical connector was weak, I added a dedicated relay to provide a better 12V source straight from the battery. I used the OEM horn wiring to energize the relay. It sounds so much better now.
ID:	474340   Click image for larger version
ID:	474341   Click image for larger version
ID:	474342   Click image for larger version
Leslierc
May 9, 2018 10:40 AM
OldBoldPilot
Jul 18, 2015 09:34 AM
rnl
Oct 31, 2013 09:09 AM
paneraiwatches
Nov 21, 2004 09:44 AM
DEETZ
Cayenne 955/957
33
Jun 24, 2004 09:39 AM
