Chassis System Failure -HELP!!!
Old Jan 17, 2014 | 05:38 AM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
Any ideas? Air suspension compressor failure?
The weird thing it is in the back, not the front. We had -12C
Looks hot though...
Old Jan 17, 2014 | 07:05 AM
Michael_s's Avatar
Michael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant future
Air suspension gave out. Others have experienced the same. Not sure if it's the compressor but I seem to recall that was indeed the issue.
Old Jan 17, 2014 | 03:26 PM
LAAlpina's Avatar
LAAlpina is infamous around these parts
For my PTT it was the compressor, replaced under warranty.
Old Jan 17, 2014 | 03:27 PM
kip's Avatar
kip
DId your rear axel sink?
Old Jan 17, 2014 | 04:07 PM
LAAlpina's Avatar
No, there was actually no noticeable change to ride height. However, I couldn't raise or lower the car. The tech said it actually was a the fuse, but when he replaced it, it blew again right away. So they just changed the compressor out and afterwards everything was fine. Good luck.
Old Jan 17, 2014 | 06:03 PM
CMLXX4S's Avatar
CMLXX4S is infamous around these parts
May just be the cold temps... I briefly experienced a "fault" on a recent trip North
Old Jan 17, 2014 | 06:58 PM
TAZ40JAHRE's Avatar
TAZ40JAHRE is infamous around these parts
I recently got this message on my PTT (see pic). The car was in the garage (as it always is overnight), I started her up to go to work, and this message immediately appeared. I noticed nothing different about the car, so I backed it out of the garage, shut her off, and restarted her. Message didn't appear and hasn't appeared since. I had the car in to the dealer to replace a tire (see my recent rant about potholes and Pirelli Sotozero tires) and they couldn't find anything wrong with it. No fault codes, nothing. It's been really cold here so maybe that had something to do with it. Who knows. I just hope it doesn't reappear.
Old Jan 22, 2014 | 04:07 AM
kip's Avatar
kip
It was the as compressor as suspected. My pump failed only in the cold, so I am pretty sure all of you getting messages have symptoms of a soon to be failing compressor. The part number was different than the original, so there are obviously reliability issues with the original one. New one works 100 in -15c.
Old Jan 22, 2014 | 05:39 PM
ikeibe28's Avatar
ikeibe28 is infamous around these parts
What are the odds. I just had the same indicator show up on my car literally 3 hrs ago and the wheels in the back looked exactly like yours. I turned off the car, waited 10 mins, restarted it and the indicator went away and it leveled itself off. Very weird.
I will have the dealer look into it so it doesn't happen again.
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
