Launch Control Not Activating
Old Dec 8, 2015 | 07:37 PM
Trauma's Avatar
Trauma is infamous around these parts
Hi - new to me 2014 Panamera GTS!
I am having difficulty with launch control - I cannot get the car to rev higher than 2000RPM, and Launch Control will not activate. I have been able to engage it one time in 7 tries, and it worked very well, but I have been unable to reproduce it since. I'm using the identical process described in the user manual.
Any thoughts?
Old Dec 8, 2015 | 10:36 PM
dphouse's Avatar
dphouse is infamous around these parts
Turn on sport plus. Hold down brake. Without any delay smash the gas pedal to the floor. Launch control should activate. Release brake.
You sure you are doing it correctly?
Any thoughts?
Old Dec 8, 2015 | 10:48 PM
Trauma's Avatar
Yes. Just like that.
Old Dec 9, 2015 | 01:44 PM
XLR82XS's Avatar
May be time for a PIWIS/dealer scan to check for faults.
Old Dec 10, 2015 | 04:34 PM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
Do you no longer have to turn off PSM (Porsche Stability Management) like you used to have to do for Launch Control in Carreras and Caymans?
With it still on, as soon as the system senses any wheel spin, it will retard the throttle response, which might explain why you're only getting 2,000 RPM.
I could be wrong.
Old Dec 11, 2015 | 11:23 AM
nephew's Avatar
nephew is infamous around these parts
All Panameras are only designed to do 3,000 launches. After that, the car will not go into launch control any more.
Haha... I think that is a nasty rumor. In the 2014 model, you need to disengage PSM by holding down the button. Then launch control will work.
Old Dec 11, 2015 | 01:51 PM
Trauma's Avatar
YES - thank you all. There was an old PASM fault that the dealer deleted. I spent several minutes with their lead tech in an abandoned parking lot launching! Now I need to go to the chiropractor.
Also - There is no limit to the number of launches you can do, and the PASM must be turned off as stated above!
Old Apr 27, 2024 | 09:13 AM
negb's Avatar
negb is infamous around these parts
https://www.718forum.com/threads/rea...ch-x431.26052/
.... just in case, where you can see how many times your Panamera was launched:
Old Apr 28, 2024 | 02:15 AM
kcjarl's Avatar
kcjarl is infamous around these parts
This is quite helpful 👍🏻
Old Mar 6, 2025 | 01:50 PM
Tonyj's Avatar
Tonyj is infamous around these parts
You may not believe this i had the same problem and it was under warranty, I took it to Porsche Leicester and it was the front right hand wheel bearing strange but true
98intrigue
Apr 22, 2016 06:17 PM
Chris_FL
Jan 17, 2016 03:16 PM
TTCarrera
Nov 26, 2015 12:03 PM
zooker
Nov 23, 2015 09:40 AM
gjr
Nov 21, 2015 08:02 PM
