Porsche Panamera 3,6 problem
Old Jun 13, 2016 | 04:23 AM
Goonie's Avatar
Goonie is infamous around these parts
My turbo makes a whining sound at high rpm gear changes. It's not the turbos. It's coming from the tranny. I think it's normal and sounds pretty cool. lol
Old Jun 13, 2016 | 04:52 AM
never674's Avatar
never674 is infamous around these parts
Haha. Its not about the sound, i was thinking anything is wrong with he car lol
Old Jun 13, 2016 | 09:53 AM
2thfxr's Avatar
2thfxr is infamous around these parts
Originally Posted by porschecayenne92
The sound is like a high frequncy whistle and sucking sound at around 5000rpm .
My 2012 P4 has made that sound at high rpm when totally warmed up, I usually do not drive that hard so only heard it that once, but I was on a spirited road rally with other Porsches and hit red line several times but heard it only that one time and my wife was with and she heard it. I have no idea what it was.
Old Jun 13, 2016 | 10:02 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Is the dual clutch shifting sound , its the same with other cars dualclutch-es trans.
Old Jun 13, 2016 | 10:22 AM
never674's Avatar
Do you know any about my other issue? My car is vibrating when it stands still and the rpm is dropping a very bit
Old Jun 13, 2016 | 10:44 AM
2thfxr's Avatar
Smile
This is normal engine vibrations. Most V6 engines are designed with a 60 degree angle between the piston banks as this design has less vibrations and all V8 engines are 90 degree designs for less vibrations. Porsche has taken a V8 design and shortened the block by 2 cylinders and added a balance shaft to try to counter the vibrations that appear due to the 90 degree angle. It does not smooth the engine vibrations 100%. Porsche figured not to be selling a lot of V6 engines so they did not design an entirely new engine as that would be cost prohibitive.
The engine rpm maybe dropping as the air conditioner compressor is cycling on and off which is normal behavior.
Old Jun 13, 2016 | 10:53 AM
never674's Avatar
Also with A/C off is making the same... The problem is the chair is also vibrating... I dont know if its normal...
Old Jun 15, 2016 | 12:38 PM
never674's Avatar
Another issue lol... I was in the parking and i putted from D in R and i got an error like "transmission error" and the car was not driving anymore... I started the car again and it worked... It is neccesary to change the gear oil or what can be the problem? I'm very dissappointed.. 1 week i have the car now and i had 3 issues...
Old Jun 15, 2016 | 01:50 PM
15PGTS's Avatar
15PGTS is infamous around these parts
what year is your Panamera?
Old Jun 15, 2016 | 05:37 PM
never674's Avatar
Originally Posted by 15pgts
what year is your panamera?
2011 140.000km
Old Jun 16, 2016 | 04:19 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
maybe things are different in Romania but why not bring the car back to be fixed if you just bought it?
anyway if that s not possible try to do the throttle reset which may help with the idle issue. Mine idles at about 850.
https://www.6speedonline.com/forums/...tle-reset.html
Old Jun 16, 2016 | 06:55 PM
never674's Avatar
I bought it from Private seller so... I have appointment at Porsche next week so we'll see how much money they will shake from my pocket for this thing
Old Jun 22, 2016 | 10:24 AM
never674's Avatar
I arrived today at the Porsche Center about my vibrate issue and they said this: the pdk gear got some problem. I have to leave the car 2-3 days to see if they repair this issue, but if they cant fix it then the gear has to be changed LOL. Very dissapointed about my first Porsche. Btw the gear oil was changed 15.000 km ago and they said me that 1.000km after oil changing the car was at the dealer with this problem(who had the car before) , so I think this problem appeared after gear oil changing.
Old Jun 22, 2016 | 11:17 AM
Are you changing the transmission only because sometimes it makes the whistle sound ? What vibration ? All the things you said I have them present in my panamera Turbo. Whistle sound is normal in all dual clutch cars , vibration and rpm droping is also common from AC , dirty maff and other issues . The message that you got from moving from D to R could be a tcu unit problem )!? Maybe you didnt pres the brake and the buton behind the shifting gear ?
Old Jun 22, 2016 | 11:59 AM
never674's Avatar
No, not because the sound. I got actually a vibration in the car, the chairs are vibrating and the RPM is dropping a very bit, they say they have to try to fix it and if they dont succeed then the transmission have to be changed ...lol
