Panamera Rear Passenger Doors Won't Open From Outside
Old Mar 10, 2021 | 06:18 PM
  #31
stealthn's Avatar
stealthn is infamous around these parts
Still have the issue, drivers rear will not open from outside, drivers front comes and goes, looks like the lock activator, considering how many places that sell them I am guessing common problem. We need to push this as a safety issue so Porsche will recall them
Old Sep 12, 2021 | 06:48 PM
  #32
MJDore's Avatar
MJDore is infamous around these parts
Originally Posted by Talleyrand
I see Stringbag posted a video. I think that is front door which has a lot in common with rear, but my rear doors were harder due to the little screws holding the outer chrome window trim. Here are some written steps and pictures that might help. My net on door actuators: 1)had to replace both front actuators when they started to fail locking. 2)one rear actuator that would not open from the outside started working after I pulled it out and put it back, then no problems in a year. Maybe it was just dropping power, or maybe something mechanical.
Rear 2011 Pana4 Inner door panel
1. Remove 2x T45 upper left. Leave one a bit in to hold the panel. Picture #1.
2. At upper right, snap out triangular plastic to remove 3rd T45 and right outer trim torx screw. Unscrew but leave the 4th T45 in a bit to hold the panel. Picture #2
3. Remove latch cover at left. Lift a little at the door edge to unclip it, then pull. Picture #3.
4. Window down. Look thru the window slot to see two torx holding the chrome outer trim to the door. I backed them out a bit, then wrapped a wire to avoid dropping them. Pictures #4, #5, #6.
5. Remove the 4th torx holding the outer trim at the far right under the plastic. Picture #7.
6. Remove six T30s holding the panel. Mine had blue dots on them and I kept the screws in order so the dots would align again. Picture #8.
7. Remove two 12pt 6mm screws at the actuator. Picture #11
8. Pull bottom of the panel, then lift. The left separated from the outer door panel about 6-8”. I did not remove the door open holder at left bottom, so rested the panel on a bucket.
9. Four connections to actuator:
a. Oval electrical: screwdriver in rectangular hole to release
b. Square electrical: pull out red clip, then squeeze base to release.
c. Inner door cable: turn the plastic to release.
d. Outer door cable: squeeze the U to pull a plastic pin up to turn. Picture #9.
10. On install, I pulled the rubber pieces off the top of the door and put them into the slots on the inner panel. Picture #10. I saw some folks replaced the 4x aluminum T45s, but I was able to torque without breaking.
I can’t thank you enough for this write-up. I was able to get to my actuator on the passenger side rear door and replace it. Great tip on the screws behind the window rubber. I never would have found those.
For the group, I had an issue with not being able to open the door from the outside. Opening from the inside was no problem. Found this thread and others and replaced the actuator. Now it works fine from the outside. Entry and drive works, all good. But now I can’t open the damn thing from the inside??!!? Hoping it’s not an issue with me not getting it put back together correctly. I’m due at my mechanic’s tomorrow to take care of another issue. Maybe I should have him check to see if it threw a code? So strange.
Old Sep 13, 2021 | 07:09 PM
  #33
rgfinnegan3's Avatar
rgfinnegan3 is infamous around these parts
Had the same problem on one of two rear actuators (both sides) I replaced, found out the cable had fallen off. I think I did not reinstall it correctly the first time. It's been great for 6 months now.
My Drivers door won't open from the outside now, requires the use of a key. Ordered actuator from FCP and will install when it arrives.
Last edited by rgfinnegan3; Sep 13, 2021 at 07:12 PM. Reason: did not complete my thoughts
Old Sep 19, 2021 | 11:10 PM
  #34
ciaka's Avatar
I have a DIY on here for replacing the actuator, with video of removing the trim and then the inner door. Dont feel like searching. I am sure if you type in actuator replacement you will find it.
Not hard, takes time, but so does anything else in life that matters.
Old Sep 20, 2021 | 07:01 AM
  #35
MJDore's Avatar
Thanks. I've already replaced the actuator. Wasn't bad. I was trying to sort why I could no longer use inside door handle and turns out I didn't get the cable attached correctly when I put the door back together. Sorted now.
Old Sep 20, 2021 | 09:54 PM
  #36
dougcayenne's Avatar
dougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura aboutdougcayenne has a spectacular aura about
Yes, I was lucky, under warranty it happended to me on my 2016 pan, passenger door in 2020.
i will search actuator. Ciaka's procedure is the BEST as always.
Deezflip
May 14, 2019 09:57 PM
gbh
Cayenne 958
Apr 3, 2012 10:14 PM
catchmyshadow
Sep 25, 2011 05:09 PM
Michael 996TT
Dec 1, 2008 04:33 AM
MWILENS
22
Oct 17, 2008 08:02 PM
