Panamera front passenger side door window switch question
Old May 4, 2019 | 12:26 PM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
I'm scratching my head on this and just realizing...there's a square hole below the front passenger window switch. Is this normal?! ...or am I missing something here If it is normal, I'm having a wtf moment
Seen some google images but it was too dark or far of an image to see.
Old May 4, 2019 | 10:18 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
Perfectly normal - just went and looked at mine, nice tiny and mostly useless pocket right there
Old May 4, 2019 | 10:26 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Yeap, I got one of those too... seems useless, perhaps it’s a spot for an ashtray, the rear door seem to have an ashtray too.
Old May 5, 2019 | 08:18 AM
XLR82XS's Avatar
Normal. Just the Germans messing with us Americans! Perfect spot for a flash drive, coiled phone charger cable, etc...
Old May 5, 2019 | 09:59 AM
Deezflip's Avatar
5 Year Member
So a hole for you all also? Not like a small tray/bucket/compartment thing?
I can see all the way down behind the door panel
Old May 5, 2019 | 11:37 AM
XLR82XS's Avatar
That's weird, got a better photo? You shouldn't be able to see "into" the door. It's just a small storage area.
Old May 5, 2019 | 01:59 PM
DogWood's Avatar
5 Year Member
should be a small pocket, felt lined, if you can't feel the bottom with your fingers you are missing something.
Old May 5, 2019 | 04:25 PM
Deezflip's Avatar
5 Year Member
Hmm, definitely something is missing. Unless I have very short fingers , it's definitely bottomless. I will check to see if it fell in or out. I'll try to get a closer pic of it. Thanks all!
Old May 5, 2019 | 09:02 PM
ciaka's Avatar
That hole is for cigars. You can put 4 cigars into it to fit perfect, and can get them out without issue, then use the lighter for a good time with your boss.
Another use - put your airpods in case into the hole, but be prepared to have them stuck there for eternity. Airpods seem to be perfect fit for that hole, ensuring one cannot get them out.
Other than that, the hole is useless. To me looks like the switch on passenger side is smaller due to having a filler plate added to existing switches that were already part of different car (cayenne/911).
Curiously, I just today, took off the driver side door panel. Expected to take 2-4 hours but took me total 30 minutes to take panel off, replace master switch (story later), and put it all back in place. Was very surprised.
Maybe can have diy for it if there is a need.
Old May 6, 2019 | 08:24 AM
XLR82XS's Avatar
Old May 6, 2019 | 08:33 AM
ciaka's Avatar
I will up you one .... to show how it is done...
Old May 6, 2019 | 08:08 PM
Deezflip's Avatar
5 Year Member
Holds cigars you say? My fingers aren't that long definitely. If so, maybe there is a bottom. Just could've sworn I saw a panel tab/clip deep down in there. Haven't had to chance to completely check it out, been busy with work. If it is a felt-type pocket, I'm just hoping it fell through the bottom. I can easily fix that and remove the door panel via those vids
Old May 9, 2019 | 05:21 AM
mziegler38's Avatar
mziegler38 is infamous around these parts
My 2018 TT has an insert in that hole. Don't know what the intended use is though
Old May 9, 2019 | 08:02 AM
XLR82XS's Avatar
2018 (971) is different from the first gen (970).
Old May 14, 2019 | 08:22 PM
Expat444's Avatar
Expat444 is infamous around these parts
It's so they can produce the same doors & trim for both LHD & RHD cars, the tiny useless storage tray is where the other switches on your driver's door go.
