cylinder 8 misfire code found
Old Feb 5, 2018 | 07:27 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
can delete
Old Feb 5, 2018 | 08:56 PM
NiceCar's Avatar
NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !NiceCar Is a GOD !
Coil?
Old Feb 5, 2018 | 11:22 PM
newporsche's Avatar
5 Year Member
if coil looks ok then do i still need to replace it?
Old Feb 6, 2018 | 11:04 AM
wraithetc's Avatar
wraithetc is infamous around these parts
Just swap coils and see if the misfire follows the coil. I had to replace my coils and they didn't show visual failure.
Old Feb 6, 2018 | 08:25 PM
newporsche's Avatar
5 Year Member
coils swapped, how long should i wait to see if the code shows up on the cylinder that i switched the ignition coil to? also when there is a misfire what does it feel like while in the vehicle? ill post pics of my tail pipes to see if there are symptoms from there
Old Feb 7, 2018 | 09:51 AM
wraithetc's Avatar
Try to rev it up high to cause it to misfire. My engine would actually vibrate badly and lurch once the coil was malfunctioning.
Old Feb 7, 2018 | 04:25 PM
newporsche's Avatar
5 Year Member
when i accelerate hard from a stand still/stop i notice a lurching sometimes but i thought that was the pdk transmission as i was told its normal on 2010s
Old Feb 18, 2018 | 01:44 PM
newporsche's Avatar
5 Year Member
should i rev it up high and see if it misfires with car in park? or does it need to be done while on the road?
Old Jun 3, 2023 | 07:28 AM
jthealy's Avatar
jthealy is infamous around these parts
Question
Did you ever get this sorted out? I know it has been a while, but I am curious. I am having a similar issue with Cylinder 8 misfire codes. I replaced my coil/plug and I am still getting it.
esinc
Aug 24, 2018 10:36 AM
Stoopstn
996tt Knowledge Base
Dec 15, 2017 10:26 PM
911_maestro
Aug 15, 2011 01:27 AM
sounddominic
May 22, 2011 05:40 AM
Zippy
Dec 23, 2009 02:39 PM
