Car Overheat. Coolant Lost. Problem Solved
Old Feb 21, 2018 | 03:21 AM
amgpan's Avatar
amgpan is infamous around these parts
As many have reported on here the inherent problem with the 4.8L TT.
I was the victim of this over the past weekend.
The plastic hoses under the inlet manifold are prone to breaking / deteriorating.
Driving along as normal, and all of a sudden, Red message regarding coolant level, and the coolant temp shot up.
Lost the A/C
And the engine temp actually increased too.
Stopped the car. Waiting for it to cool down. Refilled about 4L of water.
Continued driving for about 10 mins, then same scenario.
Steam pouring from the hood. Coolant message. Temp soaring.
Towed to mechanic. And yep, pipes / hoses broken.
While in there replaced thermostat and water pump. Water pump was just preventative. Thermostat was faulty also.
Interestingly while in there, spotted lots of carbon build up in the engine. (See pics)
Also cleaned this out while at it. They used some 3M solution that they sprayed into the inlet. I will find out the exact name.
Old Feb 21, 2018 | 05:54 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
model year and mileage??
Very interested in the intake carbon deposits. I have the 3.0TT in a 4S. I am wondering about the condition of my intake valves. Am going to try and use a USB horoscope to inspect a couple without removing the intake sometime in next few months. My current mileage is 55K.
Regards,
Chuck
Old Feb 21, 2018 | 09:19 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
yea those need walnut blasting
Old Aug 27, 2018 | 10:42 PM
rgfinnegan3's Avatar
rgfinnegan3 is infamous around these parts
After the walnut blasting, did the PT run better, did it have more power?
Did you get any pictures of the intakes after blasting?
weiyan55555
Jul 26, 2017 11:30 AM
mrhudson
Jul 20, 2013 06:52 PM
DimNSlow
Jul 17, 2007 06:54 PM
AMG ETR
Nov 18, 2004 10:06 PM
c2blk
Apr 2, 2004 07:44 PM
