Chassis System Failure
Old Feb 19, 2022 | 04:52 AM
  #61
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Check that both of the electrical connections going to the struts are properly seated. There's one next to the air line, and another connected to the center of the strut. The one on the center of the strut seems to be more prone to bad connectivity than the other one. Not sure what you mean by "shows in the instrument cluster". After that, do the soapy water test on the top of the strut to see if anything is leaking. These cars do not like to be left hanging in the air for any real length of time - even with the suspension turned off. My theory is that doing so causes the o-rings to lose their seal and then start leaking.
Old Feb 19, 2022 | 05:15 AM
  #62
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
@shrike071 Whenever I press the raise front button it says on the rightmost display to some effect height chosen. When pressed again something to the effect the front is lowered. Would definitely be a surprise when the button is pressed, the car moves up and down, but nothing shows in the right display, my interpretation...
panamera87
Feb 20, 2023 12:45 PM
pureporsche
Dec 16, 2017 11:46 AM
bsh
Sep 6, 2017 02:42 AM
Waitin4Dv
Cayenne 955/957
Aug 2, 2015 05:52 PM
jayrocks
Cayenne 955/957
Sep 23, 2009 04:47 PM
