Air suspension questions - Nitrogen Fill
The fittings are 6mm. I bought from Amazon. I also use the PA tube, not the PU tube. PA is more suitable for higher pressure. But the pressure from the compressor is about 8 to 9 Bar. So usually is fine for the common fittings and tubes.
Sorry, please pretend I'm completely stupid. Trying to make sure I don't miss something as this is new to me. Can you possibly do a step by step for how you did this procedure wise?
All the vehicles I've had with air suspension have had compressors that could fill the whole system even when on the ground. So this delicacy use new to me. Thank you for the help by the way.
PA ? PU ?
As with most pneumatic systems, the nitrogen is great for about 2-3 months!
The tank is there for a quick response of the system. When the car is unused for a certain time, the air from the tank is release through the dryer cartridge to the environment. So the pressure is about 1 bar. When start the engine the next time the compressor fill it again to about 8 bars.
Pkainzner. How is the valve working out?
any leaks when using Car?
any issues?
I'm thinking similar solution.
Looking for metal 3 way valve. I assume it will have to be 1/4" od, with push in to connect each side aur hoses.
what size is your bypass side?
Can ypu share details about parts? Valve plus tank, gauges, connector for gauges at the tank (not car tank but nitrogen tank).
Thanks for info.
any issues?
Thanks for info.
Pkainzner and ciaka,
I want to try this also. I will be installing a new air pump this week.
Questions: Tubing size is 6mm or 1/4 inch? Material for "T" and valve: Plastic or metal? Vendor for parts: Amazon, McMaster, ? What was your nitrogen initial fill pressure?
I was thinking about adding second valve between "T" and air compressor to be able to isolate the compressor for future troubleshooting.
ciaka, your air suspension information write up was great! Thanks!
Patrick
Patrick
any issues?
Thanks for info.
any issues?
Thanks for info.
panamera_lou
May 19, 2018 05:01 PM
