2015 Panamare 4 Brake Replacement
Old Oct 28, 2018 | 08:26 AM
addb77's Avatar
addb77 is infamous around these parts
Looking for information on a full brake replacement on a 2015 Panamera 4. Silver calipers/slotted rotors. Anyone have a step by step guide and tools needed? For the rear brake job, with the electronic parking brake, what else is needed? Do you need to put the the EPB in service mode? How do you do that? Recommendations on aftermarket parts?
Thank you in advance.
Old Oct 28, 2018 | 07:03 PM
ciaka's Avatar
I posted info on v8 models brakes. search for brake pad choices on this forum.
Old Nov 3, 2018 | 12:51 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Subcribed.... How many miles did you get out of the brakes?
I ve seen it done without those long rods, just put something high enough up to hold rotor so it doesn't t pull on the line.
Just like Porsche uses the wheel rods to line up wheel bolts. I ve had 2 Porsche s and never used those either.
Old Nov 4, 2018 | 06:49 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Data point on brake life: my vehicle had the rear brake pads replaced at 38,000 miles as part of the CPO inspection. This means they had <50% of original thickness left. The dealership replaced the rear pads and rotors prior to offering for sale. I''m guessing rear brake actuated limited slip was used by first owner a fair amount.
I now have 68k on vehicle. rear pads measure 8mm and fronts are 6mm. I do a fair amount of highway miles -- so don't expect particularly high brake wear.
Regards,
Old Nov 4, 2018 | 06:34 PM
ciaka's Avatar
On my end, 65k before new rotors and pads needed replace. Again, lots of highway driving too.
Old Nov 5, 2018 | 04:46 AM
cerbomark's Avatar
Regards,
What the mm pad thickness when new and what are the min mm ? Guess I m looking for easiest way to check pad life without breaking it all down.Thanks
Old Nov 5, 2018 | 05:49 AM
HP41's Avatar
For Steel Rotor Brakes: 360/330mm & 390/350mm
New Pad Thickness front, approx. 9.6mm. wear limit 2mm
New Pad Thickness rear, approx. 9.5mm, wear limit 2mm
Extra note on brake wear indicator from service manual:
If brake pad wear is indicated by the warning light, the warning contact (sender including wire and plug connection) must also be replaced.
Replacement of the warning contact can be avoided by replacing the brake pads no later than when the pad thickness is 2.5 mm
All info taken from Factory Service Manual
CPO Inspection will replace the pads/rotors prior to sale if the thickness is less than 50%.
i.e. 9.6 - 2 = 7.6 life
50% of life = 7.6 / 2 = 3.8
measured thickness at 50% = 3.8 + 2 = 5.8mm
Regards,
Old Nov 5, 2018 | 09:28 AM
cerbomark's Avatar
perfect! Thanks.
IbanezGod
May 7, 2015 02:41 PM
Polar993
Apr 21, 2015 12:43 PM
911xpress
American Muscle
Feb 11, 2015 01:35 PM
Jace
Cayenne 958
11
Nov 28, 2014 01:55 PM
