Timing chain replacement
Old Nov 11, 2018 | 10:24 AM
Yankee's Avatar
Yankee is infamous around these parts
Hello folks!
P4 with 58k miles. Stealership did the camshaft adjuster recall and told me the timing chain needs to be replaced. If I open the oil fill cap when engine is running its ruckus in there. Sounds like a dozen beer cans being thrown around. Any one done this on P4 thru dealer or DIY? What was the cost etc? I'm going DIY this if the costs are high which usually are...
On another note, would the camshaft issue have caused the timing chain problem? Or is it normal for the wear at this kind of mileage?
Old Nov 12, 2018 | 12:00 PM
Paul Rathjen's Avatar
Paul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond repute
I haven not heard of the timing chain being replaced as common practice.
A timing chain vs. a belt is for sure noisier condition, and mind sound pretty noise with the cap off too. I think that's pretty normal. These are not quiet engines or transmissions.
Old Nov 12, 2018 | 12:17 PM
tallpaul's Avatar
tallpaul is infamous around these parts
Timing chains are generally not considered a "wear item" and only replaced when needed. Even for needed, that mileage is extremely low (they traditionally run 120K+). I'd consider a second opinion.
micklert
New Member Introductions
Jul 13, 2016 07:32 AM
zzzx
Cayenne 955/957
14
Aug 9, 2013 06:11 AM
mdj09
928
Mar 8, 2013 07:28 PM
Kai@ELITEMS
Audi
Jan 5, 2011 09:43 AM
catfishez
Jun 27, 2008 06:14 PM
