Whats this in my oil pan?
Old Dec 8, 2018 | 03:42 PM
Yankee's Avatar
Yankee is infamous around these parts
Working on checking timing chain noise and potential replacement of it. Drained the oil to check the pan and found this creamy stuff by the drain plug. Its not sandy like metallic dust. Just soft like very thick cream. Didn't find any metal or plastic parts in the drained oil or the oil pan. Anyone seen this before?
Old Dec 9, 2018 | 04:03 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Looks like small area of oil/water sludge. Vast majority of pan looks clean - this can be often be found on a car that is not driven long enough to drive all the moisture out of the oil system on a regular basis. If the oil itself appears milky, then you do have a problem - water-antifreeze in oil, but from what I see, oil looks OK.
My 2 cents,
Regards,
Old Dec 9, 2018 | 05:20 PM
Yankee's Avatar
My 2 cents,
Regards,
Thanks much appreciated. That's what i read on the Porsche forums as well. Sending the oil for analysis as well as I have never done that.
OntheFly
Dec 9, 2014 04:13 AM
mobonic
Mar 22, 2011 12:56 PM
seth_horwitz
Oct 26, 2010 08:29 PM
Outkasted
944 Turbo & Turbo S
Nov 4, 2008 04:02 PM
racerjsz
Oct 15, 2005 09:21 PM
