Auto Liftgate Troubleshooting
Old Dec 16, 2018 | 09:40 PM
Small Car Lover's Avatar
Small Car Lover is infamous around these parts
Originally Posted by ciaka
Lol.
you can always wave your foot under there and discretely press remote button. Would be just like you have it.
But then I'll drop my stuffed animals and get them dirty...
Old Dec 16, 2018 | 10:05 PM
LouDA's Avatar
LouDA is infamous around these parts
lol.
You can always wave your foot under there and discretely press remote button. Would be just like you have it.
Old Dec 17, 2018 | 11:45 AM
ciaka's Avatar
...man, thinking dirty right away, wont you.
Old Dec 17, 2018 | 08:32 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Too funny... step 1...wave foot under the car, step 2....press the button
Old Dec 18, 2018 | 12:42 PM
Victory007's Avatar
Victory007 is infamous around these parts
I had a similar problem. Dealer wanted $700 to fix. I brought a pair of used hydraulic lifters on eBay for $150 - problem solved. Took about an hour to install start to finish using the posted vid as my guide. Not hard to do at all.
Old Jun 7, 2022 | 07:53 AM
stephenwinburn's Avatar
stephenwinburn is infamous around these parts
Strange solution
So, I had this problem today after disconnecting the battery to reset the CPU. In the end, I tried a number of things, but it would not even close manually, which you should be able to do regardless of automatics function. In the end I rotated the shock on its mounts and the two shock component pieces with respect to each other and it allowed me to close it manually afterwards. I then used the key fob to test opening an closing and it worked fine. So, I suspect that the shocks being even a small bit off expectations can cause the sensors to block closing to protect the shocks themselves.
Old Jan 4, 2025 | 04:02 PM
emmaslovelys's Avatar
emmaslovelys
Can you tell me where the shocks are located, please?
can you tell me where the shocks are located in the trunk please? I’m having the same problem.
machinegunt
Jul 5, 2018 11:55 PM
wolfrc
Cayenne 955/957
Feb 12, 2017 08:43 AM
Ruiner
Jul 27, 2015 01:05 PM
thaddh
Cayenne 958
Sep 21, 2012 01:27 AM
adam699
Aug 22, 2008 01:01 PM
