2010 Panamera Sport Exhaust Problem
Old Jan 1, 2022 | 10:49 AM
Turbovolt's Avatar
Turbovolt is infamous around these parts
Because I don't see the idea of ​​going to pay $ 20 for something that will do the same thing without paying anything .Thanks but I didn't even know this plastic part existed
Old May 20, 2022 | 04:10 AM
GemCity970_4S's Avatar
GemCity970_4S is infamous around these parts
Friends my new to me 2010 4S has sport exhaust and I'm noticing the same thing; unable to determine a difference in exhaust sound whether sport exhaust is turned on or off. I just took deliver yesterday so I have not had an opportunity to look. Do I need to remove some under paneling in order to get visual access to these exhaust valve / actuators?
Had to add a little photo evidence, I'm so happy about getting this car.
Old May 20, 2022 | 05:34 AM
ciaka's Avatar
Good job.
my son tells me he cam hear the difference for sure.
valves are accessible one you lay down next to car by exhaust, by hand. You can actuate by hand once there, they operate on vacuum and are spring loaded.
Old May 20, 2022 | 06:02 AM
Originally Posted by ciaka
Good job.
Thank you!
Old May 20, 2022 | 06:12 AM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
Originally Posted by stealthn
I have sport exhaust too, and you really can’t hear the difference in the car. Get someone to sit in the car and hit the button, you should see the servos activate underneath
I think a part of the reason that the difference is subtle, is that the Panameras are very insulated. Maybe it's just me, I noticed that the exhaust note is almost like... directional, one way and the tone only travels towards the rear. Sitting in the car with the windows down, doors open, valves open, and with a few revs, it still seems muffled ¯\_(ツ)_/¯.
Nevertheless, I had my son rev it to about 4-5k as I stood in the rear and listened...I have to say, it's way louder than sitting in the car. It sounds amazing! Standing in front of the Panamera, nothing, crickets ¯\_(ツ)_/¯
In other cars, the tone goes all over the place. This isn't necessarily a good or bad thing, just some observations.
Old May 20, 2022 | 10:09 AM
stealthn's Avatar
stealthn is infamous around these parts
I can hear mine with the window down, but I do have cat deletes, it sounds amazing now at WOT
Old May 21, 2022 | 04:26 AM
I was able to inspect the sport exhaust actuators at ground level. Even with the under pan in place you can get descent enough access to those actuators. After some massaging I was able manually move those pistons open and closed, however; they are still not functioning. It appeared that the vacuum lines were in tact, I actually pulled one hose off at the actuator and put my finger over the line, you could feel faint vacuum resistance but apparently not enough to open / close that butterfly valve.
The light on the sport exhaust button will go off and on when you press it, but alas no response from the actuators.
I'm getting a proper shop inspection next week and I'll have him tackle it. Its an independent Euro shop but they have a Porsche tech that was at our local Porsche dealer for years. My first sales job was at this same Porsche dealership, so I trust him
Old Feb 27, 2025 | 11:44 PM
peeps's Avatar
peeps
hey Gemcity,
I picked up a 2010 4S and I’m having the exact same issue, did you end up figuring it out what the issue was?
deckman
May 8, 2019 08:57 AM
Dpm7471
Mar 12, 2016 07:59 AM
skandalis447
Jul 29, 2011 02:59 PM
P-DUB
May 12, 2008 07:55 AM
