Panamera Turbo with Magnaflow 10790 X-Pipe installed
Old Apr 7, 2019 | 06:13 AM
  #31
RDR142's Avatar
5 Year Member
RDR142 is infamous around these parts
Originally Posted by skiracer13
This thread is becoming worthless w/o a sound clip.
i have some clips on my thread of my GTS (N/A) with fabspeed x-pipe and PSE. also, Flo ('proud new owner 13 GTS)has some before and after of his GTS w/PSE and magnaflow x-pipe installed. Definitely a huge difference in price between the two options. The N/A engines are going to naturally be louder than the turbo but it will give you an idea. Not sure that there is a distinguishable difference between Fabspeed and magnaflow but i wouldn't hesitate to spend the money again for the amount of thrill and pure joy i get from the exhaust note. it's aggressive, on and off throttle.
i'll see if i can get those clips copied over here
Old Apr 7, 2019 | 06:52 AM
  #32
RDR142's Avatar
5 Year Member
below are some clips of cold start, start up and a few from inside cabin. i don't have any exterior drive by's but will see if i can get some put together. GTS with fabspeed x-pipe
https://www.youtube.com/channel/UCzN..._as=subscriber
Old Apr 7, 2019 | 07:04 AM
  #33
RDR142's Avatar
5 Year Member
this was from Flo's thread. some before and after with maganflow x-pipe. once again, GTS N/A motors not turbo
https://www.dropbox.com/s/xp6c0krdtz...%20PM.mov?dl=0
Old Apr 7, 2019 | 07:15 AM
  #34
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Thanks for both sets of these clips, RDR142- I've heard other GTS exhaust clips before and they all seem to be great but they're all very different from the muffled Turbo sound. I was hoping for a modified turbo clip after hearing from several forum members that they have exotic sounding exhausts.
Old Apr 8, 2019 | 08:20 AM
  #35
ciaka's Avatar
Bam...
vid with sounds in original post at top of thread, Click Here as well.
Old Apr 8, 2019 | 08:36 AM
  #36
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
Thanks ciaka! Definitely deeper/louder tones at idle and low rpm revs like you've mentioned. It seems to lose the growl at higher rpm revs
Old Apr 8, 2019 | 09:23 AM
  #37
skiracer13's Avatar
5 Year Member
Yes and thanks for reposting, ciaka - poor form on my part for not checking top of your thread for updates. As Deezflip noted the aggressive sounds are more pronounced w/ the x-pipe. Assuming your car has PSE?
Old Apr 8, 2019 | 09:58 PM
  #38
ciaka's Avatar
If pse = porsche sport exhaust, then yes.
From exhaust on my other pcar, you want loud, take off secondary cats. Biggest change, but invasive sound in cabin when driving.
Low tones definitely added with xpipe. Even phone mic mot a good representation as it doesnt capture the low tones well.
Even mechanic not uh ced immediately afted first start, but I co uk ldnt since i was in cabin. Noticed once he climed in and I climbed out to listen.
Old Apr 9, 2019 | 08:09 AM
  #39
XLR82XS's Avatar
A lot of extra growl comes from cat delete - especially with the exhaust valves open. (if so equipped) I have Akrapovic and the valves open provide straight pipe/partial muffler bypass and a wonderful symphony of German V8 glory.
Old Apr 29, 2019 | 01:46 PM
  #40
Tigress's Avatar
Tigress is infamous around these parts
Love how aggressive your car sounds.
off-topic but what are your wheel/tire specs?
Old Apr 29, 2019 | 07:50 PM
  #41
stealthn's Avatar
stealthn is infamous around these parts
It’s too bad there is compressions where the cross brace is, this kind of negates the “straight through” value...
Old Apr 30, 2019 | 05:30 AM
  #42
RDR142's Avatar
5 Year Member
sent DM
cm09578
Feb 10, 2017 06:21 AM
Armytrix_F1_Exhaust
Aug 11, 2014 03:01 AM
Polar993
Cayenne 955/957
Feb 1, 2010 11:31 AM
Jeff SD
Nov 23, 2009 08:10 AM
Jeff SD
Aug 3, 2009 10:47 PM
