Radiator Hose Came Undone WTF
Old Jul 5, 2021 | 08:13 PM
  #91
ciaka's Avatar
...that's a hard one, very hard to tell, what and if anything got damaged.
Was it all in red for a while before you turned it off? Any smells, smoke (other than expected), anything else in terms of symptoms? Have you scanned codes with piwis2? The diag will tell you overheating details.
Water pump could be in play if damaged with heat (will be noisy, leaking, etc). Other hoses can start leaking if overheated. Then you have engine damage. Most of this you won't know until you repair the pipes. That's your step 1.
Then you visually check for obvious damage to components, step 2.
Then you check for vacuum in system. That's your step 3. Then you start and look for damage again.
That'd what I'd be doing anyway.
Originally Posted by Mazurda
Has anyone actually had to drive after pipe failure? I am 99% sure mine went yesterday and had to drive a few miles to get home, engine and oil temps went to red.
Old Jul 6, 2021 | 12:01 AM
  #92
Mazurda's Avatar
Mazurda is infamous around these parts
Thanks for the information, will know later in the week what the overall prognosis is.fingers crossed
03 996tt
Nov 7, 2014 10:37 PM
carrera4slakem
Sep 23, 2013 11:17 PM
Glacier
Jun 27, 2011 01:27 PM
code7rpd
May 19, 2011 07:17 AM
N1_kT
Dec 2, 2008 12:06 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
