DIY Clear Side Marker Lights
Old Oct 26, 2020 | 12:38 AM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
I’ve always felt the orange side marker lights on the bumper didn’t match the aesthetic of the car. When I 1st got my 970.2 in 2017 I looked for options to replace them. I was surprised to find that there were no OEM or aftermarket options available. Most people who felt as I did would get them tinted with film to make them disappear.
There are now 2 aftermarket options available...clear and tinted. Suncoast has the tinted. I ordered off eBay as I wanted clear lenses. Here’s a link to the ones I ordered (no affiliation):
https://www.ebay.ca/itm/2PCS-For-Por...2-e90ba3b91eb9
They arrived promptly and well packaged. Excellent quality, exact fit, and plug & play. They are clear when off but light up orange when on (presumably to satisfy North American road safety standards). They are LED bulbs so have impressive illumination.
For install:
1. Remove the two T-25 screws holding the plastic wheel well housing.
2. Pop out the existing side markers from behind. There is a retention clip (see pic).
3. Use a small flathead screwdriver to lift up and release the clip securing the wire harness.
4. Connect new side marker (need to press firmly to make connection but it WILL snap in place).
5. Reassemble.
Hope this helps!
Well packaged. Looks like OEM quality.
Left and right side markers in box.
Exact fit.
Here are the OEM part numbers of the orange side markers that I replaced. If you have the same part numbers then these aftermarket lights will fit.
Comparison to OEM. Beige is OEM orange and black is aftermarket clear.
Remove this T-25 screw.
Also remove this second T-25 screw.
Here is the location in the wheel well of the two T-25 screws that you need to remove to access the back side of the side marker lights.
Need T-25 screwdriver.
Release this clip from behind to “push out” the light.
Small flathead screwdriver to lift “up” on the wire harness clip.
New side marker installed and wire harness reconnected. Have to push quite firmly to get the wire harness to seat on the clear side marker light but it WILL snap in place!
Old Oct 26, 2020 | 09:38 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
nice write up, need s picture of the finished install
Old Oct 29, 2020 | 12:40 AM
sunnyc123abc's Avatar
sunnyc123abc is infamous around these parts
You think this will fit a 970.1?
Old Oct 29, 2020 | 07:00 AM
XLR82XS's Avatar
No - different shape.
Old Oct 30, 2020 | 09:44 PM
vkb123's Avatar
5 Year Member
Here you go! Nice day here today so gave her a wash. Also lowered 20mm through the air suspension using PIWIS 2!
Clear side marker.
Clear when off.
Shines orange when illuminated but clear when off.
Old Oct 30, 2020 | 10:10 PM
DogWood's Avatar
5 Year Member
looks great!, was it very hard to figure out how to lower it with the PIWIS II? got my hands on a PIWIS III setup and would like to do something similar
Old Oct 30, 2020 | 11:09 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
Nicely done!
Old Oct 31, 2020 | 06:40 PM
vkb123's Avatar
5 Year Member
Hey @DogWood! It took me a long time to find the process to lower using the PIWIS 2. I started by researching on-line and through the various Panamera forums. I reached out to other Panamera forums participants who had posted that they had successfully lowered using the PIWIS but got no replies. In the end, I reached out to a couple of guys (THANK YOU @Santirx and @Ray_S!!) on MacanForum and they walked me through the process step-by-step. I must admit, I never would have figured it out on my own. I will try to do up a DIY and post it for us Panamera owners.
Looks like many more are getting PIWIS 2 and 3 units so definitely becoming more "mainstream". I recently dumped my Durametric Pro cable in favour of the PIWIS set-up. So much more powerful! In the end, it cost me less to set up a PIWIS 2 (I'm using the VirtualBox set up as outlined on MHHAuto and Planet9) than the cost of the Durametric. I actually recovered money selling the Durametric Pro cable and setting up the PIWIS as my only cost was the VCI from OBD2tool!
Old Oct 31, 2020 | 06:50 PM
DogWood's Avatar
5 Year Member
vkb123 sounds great, looking forward to your write up.
I really wanted a durametric when I first got my car, especially since they are local to me, but reading up on it it left something to be desired for the Panamera.
Old Apr 25, 2024 | 10:14 AM
BillyOcean's Avatar
BillyOcean is infamous around these parts
Hello. Long time lurker, first time poster.
Has anyone had any luck sourcing these for the 970.1? I can't find them anywhere.
Old Apr 27, 2024 | 06:39 AM
XLR82XS's Avatar
These are weird looking:
Amazon Amazon
iJDMtoy may have 970.1 pieces
Old Apr 28, 2024 | 02:17 AM
kcjarl's Avatar
kcjarl is infamous around these parts
You can check on Ebay or Amazon
kosmo69
Cayenne 958
15
Jan 18, 2013 12:39 PM
gmoney
Jun 18, 2010 07:01 PM
Wheelman
Aug 2, 2007 09:59 AM
