971 Transmission Pan reusable?
Old Feb 7, 2021 | 10:04 PM
Kirkman's Avatar
Kirkman is infamous around these parts
The transmission pan on all 970s contains an integrated filter. The pan/filter must be changed with any fluid change.
The transmissIon pan on the 971s is separate - #0A7-3-1-165-00 and does not contain a filter. There is a separate "pan-shaped" filter which fits between the pan and transmission bottom - 9A7-317-189-00.
It seems to me that the pan itself should be reusable as it does not contain anything that wears, etc. Comments?
Thanks.
Old Feb 9, 2021 | 07:19 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Go to Pelican parts, enter in the appropriate info about your car and then look for a trans fluid change kit. The kit contents will tell you what is needed for your car. If the parts list includes a filter and not a pan, it is a safe bet that you do not need to replace the pan.
Old Feb 9, 2021 | 12:05 PM
Kirkman's Avatar
Thanks Shrike. I did go to Pelican to see if they had a trans fluid change "kit" for the 971s. At this time, they do not. BUT, they offer the transmission filter, gasket, drain plug and fluids separately. They do not list a replacement transmission pan. The absence could mean that that the transmission pan is reusable.
Old Feb 10, 2021 | 04:34 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Both gasket and filter are separate pieces it seems:
https://www.gaudinporscheparts.com/v...c-transmission
I agree as long as the pan has no physical damage reuse it.
Old Dec 11, 2022 | 02:44 PM
Steve971's Avatar
Steve971 is infamous around these parts
Does anyone know where the PDK fluid fill port is on 971 panamera 4S?
Thanks in advance !
Steve
Old Dec 12, 2022 | 11:07 AM
jzchen's Avatar
5 Year Member
Ours is the older 970 so I’m afraid I’m not certain it’s the same, but if it is it is right in between and above the two exhaust pipes. (Get long oven mitts to prevent burns)…
Old Mar 16, 2023 | 02:51 PM
melox2's Avatar
melox2 is infamous around these parts
Thanks in advance !
Steve
did you do a pdk oil change on your 971 as would be interested in the procedure
Old Mar 25, 2023 | 08:08 AM
ciaka's Avatar
Pdk fluid fill hole is the same as the pdk fluid dran hole.
need some pump to fill at 49C temp tran case, until iverflows, then close. I don't believe odk changed much from 970, so volume will be same, about 9qt.
Thanks in advance !
Steve
Old Mar 25, 2023 | 10:34 AM
melox2's Avatar
Thanks for info , when you take the drain plug out is there an inner plastic insert that you remove which is the level tube ? As it looks like it on a cross section of a diagram I’ve seen
turbo_secret
Bentley
Feb 12, 2023 06:01 PM
Juniorkusch
Cayenne Turbo
Jul 26, 2020 01:39 AM
blue2000s
Nov 14, 2019 12:37 PM
NormalFellow
Nov 6, 2019 04:34 PM
ciaka
Cayenne 955/957
May 14, 2013 01:34 PM
