Engine power reduced
Old May 30, 2021 | 10:56 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
Got a nice big red alert the other day,"Engine Power Reduced' car seem to be running fine, limped home and got out the ODBCII tool. P1347 Valve lift control Bank 2, did a quick search and found
"Possible fault causes
- Engine oil pressure too high or too low
- Loose contact or corrosion on connectors or lines (Power supply Solenoid valve, hydraulic valve lift control)
fired up the PIWIS III and took a look, first thing the diagnostics had me do was start the engine and check the oil pressure
was reading 3.1-3.6 bar at idle - looks like we found our culprit. want to do more checks before ordering the parts and tools to do this. (about $600 and looks fairly easy to access and change)
put the PIWIS in simulation mode and dug around a bit, found a Oil pressure Control test, think I'll run that and see what happens.
anyone else experience this error?
Old May 30, 2021 | 01:24 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Can't Say I Have.
Originally Posted by DogWood
P1347 anyone else experience this error?
I looked for my past posts. Not this one, (I confess: thankfully).
Old May 30, 2021 | 01:45 PM
DogWood's Avatar
5 Year Member
one of the few
ran the "test" I found, actually just gives you the pressure reading, with no reference as to where it should be or anything else
for reference (in case someone has some info) RPM 672, Oil pressure (absolute) 4068 hPa, oil temp. 24C
everything still makes me think it's the pressure control solenoid
Old May 31, 2021 | 06:35 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
My kingdom for a place to tap-in a good old mechanical OP gauge....
Old May 31, 2021 | 11:33 PM
jzchen's Avatar
5 Year Member
2021 Pacifica Oil Pressure.
In stop and go traffic driving home from Las Vegas today I noticed the menu item in our rental to display oil pressure. Pretty sure I saw it hovering around 30 PSI so I would say the almost 60 PSI you are seeing is very likely too high.
If you dig a little further PIWIS should say the likely causes ranked from most likely to least. What does it say? Mine is broken again otherwise I'd check....
Old Jun 1, 2021 | 06:56 AM
DogWood's Avatar
5 Year Member
lists most likely cause as the pressure control solenoid, which I've ordered, along with the 2 tools it takes to do the job ~$600 all together
Old Jun 3, 2021 | 08:00 PM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
Interested in your resolution as I've had the same issues/code at times
Old Jun 3, 2021 | 08:17 PM
DogWood's Avatar
5 Year Member
Got the part and tools on order, will install as soon as I get them, will let you know if it clears up the issue
Old Jun 4, 2021 | 12:59 PM
jzchen's Avatar
5 Year Member
I have a feeling you're on the right track, having your PIWIS. Thank you please let us know!
Old Jun 9, 2021 | 04:48 PM
DogWood's Avatar
5 Year Member
Got the part in today everything seems to be back to normal now
Old Jun 13, 2021 | 01:19 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
Of course your power is down, your car is not a turbo !
Old Jun 13, 2021 | 09:04 PM
DogWood's Avatar
5 Year Member
Yves you need to update your signature a bit - I think that list is a bit shorter now :P
cartertims
Mar 6, 2017 07:05 PM
wanderfalke
Jun 29, 2014 08:25 PM
artem-evo
Aug 11, 2012 01:36 PM
JSBear
Nov 30, 2010 04:49 PM
harvs
May 11, 2004 03:17 PM
