Strange sound from the engine
Old May 23, 2022 | 03:33 AM
Jussi771's Avatar
Jussi771 is infamous around these parts
Hi,
Panamera 970 Turbo 4.8 V8. The engine makes a strange sound. The camshaft adjuster wheel bolts (aluminum) have been replaced with steel.
So that problem bolts have been taken care of. The strange sound is exactly the same as in this YouTube video. At first, the valve cover gasket was poorly installed and leaking.
The vacuum in the crankcase disappeared in the same way if the oil cap were removed. It has now been repaired.
The engine is running normally and there are no fault codes (when the oil cap is in place). Yeah, I know the oil cap should not be removed while the engine is running.
But.... Does anyone know where that strange sound is coming?
See this YouTube video
Turbo S
Edit:
A Porsche dealer/service answered me. There is no need to worry
Suction leakage in the valve cover seal (what was before but is now fixed) or after opening the oil cap causes a variety of problems in adjusting the valve timing. The cam chain may start to hold a strange sound. It is normal.
So everything is fine now
- Jussi
Old May 23, 2022 | 04:23 AM
Jussi771's Avatar
Originally Posted by Jussi771
Hi,
- Jussi
So everything is fine now.
- Jussi
Old May 24, 2022 | 07:00 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
Good to hear
Old Jun 5, 2022 | 07:34 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Left the cap off our Toyota Sienna like that once. Nevermore, nevermore....
Thanks for sharing. I'm not sure any service procedures have one remove the cap while engine is running...
Old Jun 5, 2022 | 07:55 AM
Jussi771's Avatar
So. The cap should not be opened while the engine is running...
- Jussi
Old Jun 5, 2022 | 08:24 AM
jzchen's Avatar
5 Year Member
The engine on the Sienna made funny sounds even after replacing the cap.
Since the engine on the Porsche is much much more expensive I would highly recommend not trying that unless you have official instructions that somehow say to do so, so please don't for your wallet's sake, just in case....
Old Jun 23, 2022 | 10:57 AM
lapraer's Avatar
lapraer is infamous around these parts
Great video / motor noise
The motor sounds noisy over and above removing the filler cap. Is that normal, have you had any more replies to what is happening. When I removed oil cap and put it back on my noise level that was normally present reduced. Noise level sounds like lifters rattling.
Old Jun 23, 2022 | 02:16 PM
Jussi771's Avatar
I got an answer from a Porsche dealer. The cap should not be removed while the engine is running. The vacuum disappears and causes malfunctions, etc. The same sound is heard if, for example, the valve cover gasket is not properly in place. Appear the suction leak, just like in my Panamera. Well, it is repaired a no noise anymore. But if I remove the cap, a strange noise appears. There is no fault or problem.
- Jussi
Old Aug 27, 2023 | 10:59 AM
panny's Avatar
panny is infamous around these parts
- Jussi
Hi Jussi,
I have the same problem in my Panamera. Strong vacuum and strange noise when a open the cap.
What was the problem in your car?
Old Aug 27, 2023 | 10:45 PM
Jussi771's Avatar
Originally Posted by panny
Hi Jussi,
It is normal. If you remove oil cap, vacuum dissappear and cause noise you heard. Do not remove oil cap when engine is running.
Old Aug 28, 2023 | 03:46 AM
panny's Avatar
Thanks Jussi.
Then maybe people that have poor vacuum in the engine, have some gasket leakage?
Old Aug 28, 2023 | 07:27 AM
Jussi771's Avatar
Hi,
Correct. When engine is running and the vacuum disappears in some reason, you can hear noise. For example oil cap is removed, but also if there is a leaking gasket or some vacuum pipe.
- Jussi
Old Aug 29, 2023 | 01:53 AM
Marc13190's Avatar
Marc13190 is infamous around these parts
You can control oil separator membrane its a problem on panamera.
Old Aug 29, 2023 | 02:04 AM
panny's Avatar
Yes! thanks I will do that
Old Sep 4, 2023 | 11:41 AM
Turbovolt's Avatar
Turbovolt is infamous around these parts
Yes change only the membrane it will be fine
NormalFellow
Nov 19, 2024 06:43 AM
Richard Godsall
Cayenne Turbo
Jan 23, 2022 03:38 PM
mrtutis
Cayenne 958
Mar 15, 2021 03:31 AM
sosspistache
Jun 24, 2019 04:03 PM
onurbattal
Jun 5, 2019 07:47 PM
