Drivers door doesn’t lock with remote Please help
Old Jan 23, 2023 | 08:41 PM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
Usually the car horn chirps when locking the car. I noticed this first and wonder why it wasn't chirping, I thought maybe a faulty horn but discovered a particular door wasn't locking.
Just curious with anyone with the door actuator issue, if you've noticed that the horn no longer beep/chirps?
I've just been procrastinating on replacing the actuator.
Old Jan 23, 2023 | 09:08 PM
gvenz33's Avatar
gvenz33 is infamous around these parts
yup. I get no chirp
Old Jan 30, 2023 | 11:20 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
Hey all I've been searching for awhile is this the proper door lock actuator for drivers side door lock?
Amazon Amazon
Old Jan 30, 2023 | 11:28 PM
gvenz33's Avatar
https://www.amazon.ca/URO-Latch-Actu...47656853&psc=1
Yes that's for the driver door. Double check that its the right plug. There may have been 2 different versions and 8 pin and a 9 pin. Even though I got mine installed its not 100%. I have to click unlock, lock, unlock on the remote in order for me to open the driver door. I don't get a chirp. Not a battery issue as I got a brand new battery installed for that same thought. If you read above I have issues with my front left (driver 's) and rear right (rear passenger's) doors not locking or locking. And no chirp. I have already given up.
Old Jan 31, 2023 | 07:08 PM
newporsche's Avatar
5 Year Member
Ok ill check to see if its 9 pin it 10 pin. Its supposed to be 9 pin for our cars correct?
I wonder if the different branded actuator is causing you issues...if you get the original Porsche branded actuator maybe it will work correctly? Or maybe some reset procedure is needed?
Old Jan 31, 2023 | 09:14 PM
gvenz33's Avatar
I don't know. It was pulled out of a Porsche so not sure about it being a different brand.
Never thought of a reset procedure. I will check and see if there is an option and if it works. Thanks for the suggestion.
Old Feb 1, 2023 | 07:15 AM
Deezflip's Avatar
5 Year Member
Something just occurred to me about the 9 pin versus the 10 pin or if was previously mentioned already, it may be depending on if the Panamera has the Entry&Drive system?
Old Feb 1, 2023 | 10:37 AM
gvenz33's Avatar
So my plug has 9 pin (room for 10 but one not used. The others were 8 pin. I have manual entry. Have to click remote and stick key in ignition. Not sure if that helps.
Old Nov 16, 2023 | 05:47 PM
ctesales's Avatar
ctesales is infamous around these parts
Same thing on mine
I'm experiencing the same exact thing.
Originally Posted by gvenz33
Thanks for the response. That’s my thought too but was swayed because it happened on the rear passenger door first and then switched over to the front driver’s. I did purchase a driver’s door actuator and will see if this works. Will keep everyone posted.
Old Nov 16, 2023 | 06:00 PM
newporsche's Avatar
5 Year Member
Keep me posted too I have same issue.
dealership says they dont sell the door lock actuator itself???
Old May 11, 2024 | 08:12 PM
ctesales's Avatar
Same thing hapened to me..
JW996
Mar 28, 2018 04:54 PM
dmilzoff
Jun 26, 2017 08:19 AM
VGLNTE1
Jun 11, 2015 02:38 PM
zuman
Nov 17, 2014 06:59 AM
p's pcar
Dec 18, 2011 11:31 AM
