Upgrading the speakers.
Old 03-21-2019, 01:37 AM
Kayvan1347's Avatar
Kayvan1347 is an unknown quantity at this point
Hi all. My Panamera came with standard audio system which was awful. I change it to Helix V8 DSP amp and Focal amp for the Audison 400 W sub in the trunk. The setup and sub is fantastic but I think the existing dash and door speakers are not really good enough.
Any one has any recommendations and also instructions how to remove the dash speakers cover to change it. The door are more complicated I think. I will try the dash speakers first if it is easier to do.
Old 03-21-2019, 06:37 AM
LGARCIA's Avatar
LGARCIA will become famous soon enough
I have not tried doing this but I’m interested in your results!
Getting to the door speakers will require for you to remove the door panels, you’ll find step by step instructions in Youtube. You can also add sound dampening to the door panel while you work on the speakers.
Old 03-25-2019, 07:57 AM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
I can tell you that the door removal is not complicated at all, there's a how to around here that shows how to do it. I'll also be doing a speaker upgrade soon in the Panny.
Old 03-26-2019, 09:37 AM
Kayvan1347's Avatar
Is there any YouTube link that shows how to remove the speakers covers on dashboard on Panamera?
i think there are a few how to remove the door panel.
Old 03-28-2019, 09:21 PM
Kayvan1347's Avatar
Hi all,
dors anyone knows that middle speaker ( midrange $ on front doors can be accessed by just removing the cover trim? So maybe no need to remove the door panel?
Old 03-31-2019, 06:30 AM
OEkun1's Avatar
Originally Posted by Kayvan1347
Hi all,
Pulling the panel is an easy way to ensure you don't break anything. My suggestion
Old 04-02-2019, 07:51 AM
Paul Rathjen's Avatar
Paul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond repute
partial hijack - whats the simplest option to get a bit more, tight low end response out of the sub system? I have the Burmester.
Old 04-02-2019, 08:50 AM
OEkun1's Avatar
You may want to pull your subwoofer and apply some sound deadening material to the plastic. That is of course if it's similar to the Bose unit. Alternative is also to consider a custom sub/amplifier...but I'd try the sound deadening first.
Old 04-05-2019, 11:34 AM
Kayvan1347's Avatar
To change the midrange speaker on middle of the front doors , is from behind panel or from trim outside. I saw this picture in the internet.
i don’t want to change The woofer on buttom of the door.
PJPR01
03-05-2019 08:22 AM
Vergis
08-21-2017 10:57 AM
terminal_ac
02-13-2016 12:52 PM
E. coli
07-03-2009 05:18 AM
PrecisionPorsch
04-28-2009 02:31 PM
Quick Reply: Upgrading the speakers.
