"ADS off" message
Old Apr 26, 2026 | 12:16 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
"ADS off" message
Good morning,
I just finished replacing the dampers on my 2010 Rapide, and I am now getting a "ADS off" error message on the dash, and the suspensions go into the "harsh" mode...
I ran my scanner and it's giving me 2 codes:
- C110E = Left rear damper valve fault
- C110F = Right rear damper valve fault
I can erase them, but they will show up the next time I start the car.
I am not getting error messages for the front dampers, so I assume it's not the module.
Any help appreciated, thank you!
Old Apr 26, 2026 | 01:43 PM
J doubleU's Avatar
Bad new parts? Plug in the old ones and clear/cycle the key. I'd venture to say continuity to the new rears is open circuit.
Old Apr 26, 2026 | 03:30 PM
EJ_Rapide's Avatar
I hooked up my scanner again and I noticed a couple of interesting paramaters.
First, the "calculation data" for the right rear damper is at 253, when the other 3 dampers are at 0 or 1.
I tried reconnecting the "old" damper but the result is the same...
Then I looked at the measured and commanded currents to all 4 dampers, and all 8 values remain at 0, even when I am driving.
Now I am starting to actually suspect the ADS module...
Did I miss something? Is there a reset procedure? Or a programming?
Old Apr 26, 2026 | 04:37 PM
J doubleU's Avatar
Modules don't just die. Did you try a battery disconnect?
Old Apr 26, 2026 | 05:09 PM
J doubleU's Avatar
Also, system sees a fault so it's setting all dampers to failsafe. I would recheck connections on all 4. Obviously fronts are easy to check. Perhaps you just have the 1 rear that is at fault.
Old Apr 26, 2026 | 08:45 PM
EJ_Rapide's Avatar
Checked all the connectors, did the battery disconnect for 1 minute, tried to plug back a "old" damper... same results 😒
Old Apr 26, 2026 | 09:30 PM
J doubleU's Avatar
So much for a simple R/R.
Old Apr 27, 2026 | 04:33 PM
EJ_Rapide's Avatar
Just checked both fuses, they both seemed fine.
What I noticed earlier is that if I press the ADS button on the console to turn on the bypass of the ADS system, then I don't have an error message.
As soon as I try to reactivate the ADS system => the message comes on...
Old Apr 27, 2026 | 09:29 PM
J doubleU's Avatar
Going by your codes before, you said rear. Then you had 3 good readings. I'd try getting an Ohms reading on the new vs old damper. Still thinking you have a bad new part.
Old Apr 28, 2026 | 10:43 PM
EJ_Rapide's Avatar
I tested continuity on the rear dampers, and sure enough, both seem to be open circuits
Front dampers have continuity.
I'll try and connect two "good" dampers and see if I can get the error to go away.
Will update soon.
Thank you!
Old Apr 28, 2026 | 11:03 PM
J doubleU's Avatar
Sounds like a progressive thing. Fingers crossed it an easy fix.
Old Apr 29, 2026 | 12:22 PM
EJ_Rapide's Avatar
Thanks to the docs that @UltraMarine posted, I found the actual procedure to test dampers:
Again, the 2 suspicious dampers didn't return any Ohm readings, whereas the "good" dampers returned a value within the range.
So my next step is to replace the 2 rear dampers (of course the more difficult ones to replace) and retest.
Will update as soon as it's done.
Thank you @J doubleU for all the help!
Old May 16, 2026 | 11:38 PM
EJ_Rapide's Avatar
Finally replaced the rear shocks with good units, the message is gone, and the car is back to running properly!
Old May 17, 2026 | 02:51 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Any difference in handling since the shock replacement?
Old May 17, 2026 | 03:02 PM
EJ_Rapide's Avatar
I haven't driven long enough to notice a real difference.
For now I am just enjoying my car being back on the road
