Tech / How To
seafoam
Old Apr 19, 2007 | 10:14 AM
Kman's Avatar
Kman is infamous around these parts
seafoam
1st i wanna say, Hi, and im not sure if this is right section to post this.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
i was reading about it on an E30 website. the guys over there said it improved idle, and various other things, removes carbon. i guess you put 2/3 in the gas and u suck up the other 1/3 into the vacumm lines. to clean the injectors, valves and manifolds. not sure if i would use it with a turbo.
anyone have input i want to use it in my 77 911s
Old Jun 14, 2007 | 09:03 AM
domlee's Avatar
domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !domlee Is a GOD !
Sorry to dig up this old thread (2 months old).
But in case you never got an answer.
Seafoam = diluated acetone.
Putting it in the gas tank, acts the same as fuel system cleaner. Cleans the gas tank all the way to the fuel injectors. (Althought the best way to clean injectors would be to send them out for professional cleaning).
The vacuum line...cleans some of the engine internals.
Lastly, putting it in the oil. Much like other crankcase cleaners...it attempts to clean out the old burnt oil. Just be sure to do an oil change afterwards to put in fresh oil.
Old Jun 15, 2007 | 12:36 PM
Seven77's Avatar
Seven77 is infamous around these parts
Thumbs up Using Seafoam
I've used this on a older delivery van I picked up. It was a Chevy Astro with the 4.3L. It had sat with old gas for approximately 2 years. Upon driving it the first time it was running rough as expected. I had heard of people using this for boats and RV's that get stored for half the year. So we tried it and it worked wonders on it. At first it blew tons of carbon out the exhaust, but than burned clean as it purged from the system. It worked well for that application, but I am not endorsing it only because I have no experience with it in turbo vehicles. I only used it once but for that one experience it worked well.
Old Jun 24, 2007 | 04:40 PM
Dan's Avatar
Dan
Dan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to behold
I have used it and it works really well. I noticed a large decrease in gas consumption.
Old Aug 2, 2007 | 11:57 AM
B-Ver!'s Avatar
B-Ver! is infamous around these parts
I've used it as well and it made a difference.
Old Oct 17, 2007 | 12:21 AM
RandomName's Avatar
RandomName is infamous around these parts
another amen on that. used it and car ran awesome and clean afterwards. Smog test proven (produced very very very low emission for a 10 year old car)
Old Oct 19, 2007 | 05:28 PM
elduderino7's Avatar
elduderino7 is infamous around these parts
been meaning to try this
Old Oct 28, 2007 | 11:28 AM
RandomName's Avatar
where do you find the vaccum line/brake booster hose on a na 996?
Old Oct 29, 2007 | 01:49 AM
19000rpm's Avatar
19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute
You should be able to get to one easy on the intake, there are plenty. Be careful not to load up the engine with the stuff or else it will set off the check engine light. Just keep up the revs when adding it.
Old Oct 30, 2007 | 10:16 PM
RandomName's Avatar
I'm new to the 996. I'm looking at the engine bay and cannot find where the vacuum line is located. Could someone please point out specifically where this is located?
Old Oct 31, 2007 | 08:10 PM
GarrettM's Avatar
GarrettM is infamous around these parts
Do 33% in the gas tank, 33% in the oil, and 33% in the vac line..
Old Nov 3, 2007 | 10:36 PM
Euclid's Avatar
Euclid is infamous around these parts
I got an O2 sensor CEL shortly after introducing seafoam to my gas tank. Coincidence or not, I'll never know.....
Old Nov 4, 2007 | 11:00 AM
RandomName's Avatar
it says O2 Sensor safe. but searching around it seems like pcar computer is a bit sensitive to this stuff. I went with bottle of Techron instead.
Old Nov 4, 2007 | 04:20 PM
Euclid's Avatar
My local dealership recommended not to run any of these cleaner products. Our motors will probably blow up before they'd benefit from something like this. :-p
Old Nov 5, 2007 | 05:12 PM
kraeburn's Avatar
kraeburn is infamous around these partskraeburn is infamous around these parts
Here is a DIY that may help you out:
http://audizine.com/forum/showthread...ht=seafoam+diy
