KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
yeah I saw that as well. I guess they could batch fire a second set of injectors using the other 2 outputs. however I thought they were using 6 on this build.
#TeamAIM
#TeamAIM
Last Monday, the motor was fired up. It was warmed up. RPM's did not exceed 2,500. It was then turned off and let cool.
Neil will now disconnect the exhaust and remove the covers and adjust the valves. We had spent about 60K designing and making billet cams several years back.This was detailed in this thread. The cams are single lobes with solid lifters. We need to make sure these babies are adjusted correctly. There were no oil or coolant leaks.
After a complete check Neil will re start the motor and finish the tuning process.
Sometime next week myself and Rob from Scargo Racing will fly down to Monrovia and observe the motor going through it's paces before it is crated and shipped back to Scargo Racing. It should be a plug and go installation as the motor was fitted and removed in a car in Monrovia several times to verify all points of connection, electronic connections and checked for chassis clearances.
I have spoke with Neil at Performance Development and Rob at Scargo. Neil said everything checked out perfect from the first warm up dyno. Rob is schedule to go to some event next week and then off to a well deserved vacation. Rob and I will fly down right after he returns from his vacation in early October to buy off on the final engine dyno.
A dyno that is coupled directly to an engine is known as an engine dyno. It is the only true way of knowing how much hp a engine produces without transmission, drive train, etc. As a note, once the engine is installed in the chassis, it will be tuned again on a chassis dyno,
I have a correction. Performance Developments is located at 1643 Monrovia Ave in Costa Mesa CA.
I truly sorry for the delay. We are not completed yet. There was some swapping of some engine management parts parts between Rob at S Car Go and Neil at Performance Developments. Neil now has everything he needs to proceed with final check out for the engine dyno testing.
I spoke with Neil last week and am awaiting his call that he is ready for myself and Rob to head down to his shop and witness the final engine dyno run.
I recently received the following e mail. The date he is referring to is the date to view the engine dyno runs.
Hello Chad,
Just wanted to let you know the harness is almost complete. We tested it and now it’s getting covered and sealed up.
Next week I hope to be in a position to set dates etc.
Have a great weekend,
nh
Kind regards,
1643 Monrovia Ave.
Costa Mesa, CA 92627
nh
Kind regards,
1643 Monrovia Ave.
CJV,
Any updates? Been following this build since the early 2000s. When did the project originally start? Would be great to see a full set of pictures, videos, build sheet and performance specs when all is said and done. What's the latest on turbo choice, power and responsiveness? Wishing you well.
