Wheels/Tires
Volks TE37 Questions
Old Oct 30, 2007 | 09:26 PM
auto-xr's Avatar
auto-xr is infamous around these parts
I posted this on the 996 board. Just want to see if anyone has the 9" ET 46 front wheels.
Old Oct 31, 2007 | 09:26 AM
TT/T's Avatar
TT/T is infamous around these parts
Old Oct 31, 2007 | 12:03 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Are you asking if they will fit?
Old Oct 31, 2007 | 05:02 PM
auto-xr's Avatar
I checked the offsets and I am pretty sure they'll fit. This is based off of an 8" ET50 rim being coupled with 15mm spacers and the wheel coming out flush with the front fender. I think it may extend past the fender by a mm. This is all just theory so I wanted some real world application.
Old Nov 1, 2007 | 09:18 AM
Yes, they should fit just fine. Brake clearance wont be an issue, and as far as lining up with the fender, it will be close. Are you putting them on your C2?
Old Nov 7, 2007 | 01:09 PM
auto-xr's Avatar
Yes, these will be on my 996c2. I'm in the process of buying te37s (8.5" F and 11" R) now but the set will have 8.5" fronts. I'm seriously considering moving up to the 9" fronts thus all my questions. My goal would be having the the option to run 265s up front. Not saying I'd do that but I would like the option since quite a few tire manufacturers carry 265s and higher but only have 225 or 235 options for the front.
Old Nov 8, 2007 | 07:45 PM
flat6's Avatar
flat6 is infamous around these parts
I stumbled onto a set of TE's on Ebay last night. 8.5's and 11.5's I beleive. 19's though. take a look.
Old Nov 8, 2007 | 09:12 PM
auto-xr's Avatar
Thanks for the heads up. I think I'm going to have to pass though. The 19s are a little heavier and I don't think there are enough tires to choose from in that size yet. Also, I don't think the 19s come with a 9" front option. Lastly and most importantly, the rears are in widebody offsets.
Did some research and found this info on the TE37s for anyone interested.
TE37
18x8.5 18lbs
18x9 front 18.5lbs (estimated)
18x10 rear 19.5lbs
18x11 rear 20.5lbs
19X8.5 20lbs
19X11 21.5lbs
http://www.rayswheels.co.jp/cgi-bin/...odelName=TE37P
Here are the specs on the Champion RG5 (one of the lightest out there for regular street/track use) for a comparison. They are much more expensive.
RG5
18x8 front 18.5lbs
18x8.5 front 19 lbs 2 oz.front
18x10 rear 19.5lbs
18x11 rear 19lbs 9 oz.
CCWs C10s The price is quite comparable to the Volks. They look arguably better than the TE37 but that is purely subjective.
c10 (estimated as they have not been officially released yet.)
18x9 Front 19.4lbs
18x11 rears 20.6lbs.
Hopefully someone will beat me to the 9" TE37 fronts and let me know how they are
Old Nov 15, 2007 | 11:35 AM
auto-xr's Avatar
I have another question that came to mind. I know the Porsche center caps won't work on these wheels, but I heard that the standard Porsche lug nuts may not work as well. Can anyone that knows if the lug nuts will or won't work chime in?
Old Nov 15, 2007 | 12:30 PM
Caps wont work, but its hard to say if the lugs will work or not, just hafta try them. It varies from wheel to wheel.
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
COBB Tuning
Nov 9, 2015 08:02 PM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
