Wheels/Tires
Question about anti seize on lug nut bolts
Old Apr 16, 2009 | 10:05 AM
cjaz's Avatar
cjaz is infamous around these parts
I am going to be putting the 17mm rear spacers on my car when i install a set of sport techno wheels on my turbo. Should i put anything on the spacer studs that the wheel will mount to? The spacers also came with black aluminum (i think aluminum) lug nuts.
I also realized as i wrote this since i won't be using spacers for the front, i am going to have black nuts on the rear and silver on the front. This might look a little funny. Now I wish i had silver for the rear.
thanks
Old Apr 16, 2009 | 11:21 AM
Steve's 996's Avatar
Steve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud of
Anti seize on lugs is a no no.. Use it for items that are under a great deal of heat. Spark plugs, head studs, exhaust nuts and bolts, etc.
Old Jan 16, 2011 | 01:13 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
What about between a spacer and the axle? I've heard of spacers essentially welded to the axle without anti-seize. Nothing short of a hammer and some brute force would get them loose.
Old Jan 19, 2011 | 03:03 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Putting a light coating of the anti-seize on the both faces of the spacers to keep them from welding to the drive hub is a common fix for that problem. I use it on the wheel faces that sit against the hub to facilitate easier removal of the wheels for the same reason. I am unaware on any long term negative effect to either your wheels or wheel hubs from the paste.
Old Jan 19, 2011 | 03:07 PM
bonehead's Avatar
Thanks Dadio. Exactly the response I was looking for. What brand do you use?
Old Feb 6, 2011 | 08:08 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
That's funny. I've been putting anti seize on lugs for years and I've never had a problem. That includes 21 years of track.
Old Feb 9, 2011 | 07:33 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Using any type of lubricant on the lug bolts (or lug nuts) causes erroneous torque application.
Not recommended.
Old Feb 15, 2011 | 08:30 AM
jmc777's Avatar
jmc777 is infamous around these parts
I've been putting a little on my wheel hubs for years to prevent the wheels from "welding" themselves to the hubs. No problems so far.
007 Vantage
Sep 4, 2015 06:55 PM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
