Door edge guards.....
Old Dec 12, 2014 | 12:24 AM
Fester's Avatar
Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !Fester Is a GOD !
Question Door edge guards.....
Anyone has experience with some good quality door edge guards ..the kind that takes occasional unintended beating and also doesn't stand out??
Old Dec 12, 2014 | 05:00 AM
plenum's Avatar
plenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant futureplenum has a brilliant future
Hi! Believe it or not I found that the vinyl door edge guards that SuncoastParts sells on their web site for $12.95 work just great! I installed nearly a year ago, and in two cases they have saved me from chips on the edge of the driver's side door (sometimes my wife just can't park close enough in our garage! )!
Here's a link: Door Edge Guards
Very easy to install -- and nearly invisible to see on my 4S! Just take care and be patient, make sure the material is warm, work from top of the door edge where you want to start and move down. The vinyl "wrap" conforms nicely to the curve of the door. I found the length to be a bit shorter than I wanted, but since there are 4 per kit, you can certainly use 2 per door! Oh, and make sure to keep a majority of the material on the outside of the door edge, and only wrap a small portion around to the inner-side -- this will give you the maximum protection for your door!
Hope this helps!
Old Dec 12, 2014 | 09:04 AM
cairo94507's Avatar
cairo94507 is a jewel in the roughcairo94507 is a jewel in the roughcairo94507 is a jewel in the rough
I second the vinyl, or clear bra edge guards. I add those to all the cars on which I have clear bras installed and they work well without being obvious.
Old Dec 12, 2014 | 01:31 PM
plenum's Avatar
Here's an iPhone pic of my drivers-side door. You can just make out the vinyl edge guard strip.... the guard being a straight cut and the door having a significant curve, you probably won't get a perfect conforming curve line. At least I didn't! But the vinyl is all but invisible and offers peace-of-mind!
And here is a bit closer look. You can almost see a small mark (lower-right of the door handle) where my door touched the wife's SUV and mussed-up the vinyl, but didn't make it through to the paint beneath!
Old Dec 13, 2014 | 12:04 AM
Fester's Avatar
Nice job on the edge guards - looks neat and I do see the mark! Looks like it did what it supposed to. Very helpful, thanks jawells1!
Old Dec 13, 2014 | 01:52 PM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
+1 On the Suncoast door edge guards. Easy to install and does the job
NIKAS
Aug 20, 2019 07:53 PM
glenn macisaac
Cayenne
Sep 28, 2015 12:16 PM
BLKMGK
Sep 19, 2015 03:51 PM
kahala997s
Sep 15, 2015 05:15 PM
AlecS
Sep 12, 2015 10:51 AM
