Interchangeability of brake rotors/calipers
Old Feb 15, 2016 | 12:06 AM
Stephen Belcher's Avatar
Stephen Belcher is infamous around these parts
Hello all
I'm a happy 991 Carrera owner. I have found that the stock brakes are not holding up to track days. My front AND rear rotors are warping and my pads are disintegrating - time for an upgrade.
I drive the car around the parking lot after a solid 20 minute session to let the brakes cool. Transfer of material isn't a problem.
What's the best way to approach this problem? I have looked at some Brembo setups online and they're very pricey, and I still don't know if it's a simple bolt on setup.
What do you think?
Old Feb 15, 2016 | 08:30 AM
998M's Avatar
998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of998M has much to be proud of
Check out Girodisc. They are slotted instead of drilled which gives them better durability. The fronts are 10mm larger and 3 lbs lighter. There is an extender that allows for the extra rotor clearance. They are cheaper than a full brake upgrade kit. These rotors with a more aggressive track pad work really well. I have them a they have proven to be more durable than the stock.
Marc
http://www.girodisc.com/Girodisc-Fro...2S_p_6517.html
Old Feb 15, 2016 | 11:01 AM
Marc
Hello Marc,
Thanks for your response. Do you know if there's a simple bolt on setup for rotors bigger than 350mm? I would prefer to go bigger if possible, as long as it's a fairly easy upgrade.
Stephen
Old Feb 15, 2016 | 11:07 AM
998M's Avatar
I have no idea but I would doubt it. The 10mm is pretty significant. Not to mention the change from drilled to slotted and the change in material.
Marc
Old Mar 5, 2016 | 07:37 PM
Maxhouse97's Avatar
Maxhouse97 is infamous around these parts
Suncoast sells a kit to upgrade to S brakes up front. Think it's around 2 grand. I'm waiting to see if they come out with a similar kit for 991.2 rotors, which are 2 piece.
Old Mar 6, 2016 | 01:14 AM
CSK 991 C4S's Avatar
CSK 991 C4S is infamous around these parts
Here is an upgrade if you already have S brakes.
http://www.racingbrake.com/RB-Iron-R...por-irk-14.htm
Old Mar 6, 2016 | 07:07 AM
mtony's Avatar
mtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond reputemtony has a reputation beyond repute
I would start by simply upgrading to a track pad.
Old Mar 6, 2016 | 09:09 AM
powdercoatmike's Avatar
powdercoatmike has a spectacular aura aboutpowdercoatmike has a spectacular aura about
yeah, fluid and track pad upgrades should get you there.
turbogts
Feb 29, 2016 11:06 AM
chamstra
Jan 31, 2016 05:34 PM
robertwroth
Jan 30, 2016 07:40 PM
Jonhunt
Jan 30, 2016 11:58 AM
