LED for license plate
Old Mar 28, 2016 | 02:06 AM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
Has anyone replaced theirs with aftermarket? And is it brighter?
Old Mar 28, 2016 | 09:23 AM
AZN Optics's Avatar
AZN Optics is infamous around these parts
Yes, it will be appreciably brighter, and also whiter giving you a much cleaner look. Rear plates use a set of 36mm festoon LEDs, and you'll need canbus versions to prevent codes. Let us know if we can help you out with our plug and play replacement.
Old Mar 28, 2016 | 12:04 PM
///M Kevin's Avatar
Pm sent.
Old Mar 28, 2016 | 12:51 PM
911Konigin's Avatar
911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of
mmmmmm....................not sure I want the cops to have a better view of my plates!
Old Mar 28, 2016 | 12:59 PM
AZN Optics's Avatar
Originally Posted by ///M Kevin
Pm sent.
PM Responded
I hear that a lot... but not like plates are that hard to read anyways and it's not like you're running from the cops if they light you up.
Old Mar 30, 2016 | 08:47 AM
hoot's Avatar
hoot is infamous around these parts
Any pics with them installed?
Old Mar 30, 2016 | 10:45 AM
AZN Optics's Avatar
Turns out OP was looking for lights for his 2014 not the 2011 I thought he was asking for that was listed in his sig. 2013+ models has integrated LED rear plate lights that require housing change and some rewiring to replace.
Here's an example of what our LEDs look like in rear plate:
Old Mar 31, 2016 | 10:36 PM
TAch Miami's Avatar
TAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond repute
This is true but brighter lights would only help the speed and red light cameras.
Old Mar 31, 2016 | 11:14 PM
AZN Optics's Avatar
Those cameras can easily capture your plates with dingy halogens. The flash lights you up to the point you could run no lights and it'd still get your plate, so LEDs don't matter in any law enforcement situations. They will aesthetically help the car look better though. That's why you see newer models with integrated LEDs oem.
airbusdrvr
Apr 5, 2022 11:56 PM
Clearlaker
Mar 27, 2016 02:15 AM
pabafree1995
Mar 24, 2016 05:09 PM
Polar993
Mar 24, 2016 01:04 PM
