Auto start stop function not working
Old Jan 15, 2018 | 06:43 PM
cclcal's Avatar
cclcal is infamous around these parts
Originally Posted by steve-t
I
I experienced the same thing with my 2012 sI brought it to be checked twice both times they told me it was ok. Then I let them keep it overnight and they determined it was the battery even thought it checked within spec. They replaced the battery and it has worked normally since
thanks for the info...I'm guessing that's what the issue is as well. Since I'm in no rush to have it functional, I think ill wait a little longer before replacing my battery
Old Jan 15, 2018 | 08:54 PM
steve-t's Avatar
steve-t is infamous around these parts
My car is a CPO. if yours is as well your dealer will replace the battery under warranty because that’s the only way to get the auto restart function to work. Otherwise, I’d leave the original battery in the car as mine worked fine in all weather and I live in the north east
Old Jan 29, 2018 | 02:46 PM
cclcal's Avatar
Last week while on a slight incline at a stoplight, the car did the hill hold function and the auto start-stop kicked in. When the light turned green, i heard a nearby car engine start, then i realized it was my car. My auto start-stop had worked for the firs time. it then occurred again a few stop lights later, the RPMs went to zero, a circular arrow w an A in the middle went green. I was so excited that it actually works.
It hasn't happened since....but at least I know it's functional.
Old Jan 29, 2018 | 03:10 PM
PorscheCrazy's Avatar
very very weird
could be a bad connection somewhere, which maybe the incline caused the part to connect and therefore start/stop to work? my guess, which is probably completely wrong . . .
Old Feb 1, 2018 | 07:31 PM
Porschejeff's Avatar
Porschejeff is infamous around these parts
Be happy it isn't working. I hate mine!
Old Oct 23, 2018 | 12:55 AM
ammar.malik's Avatar
ammar.malik is infamous around these parts
Also in San Diego, the Start stop does not work battery socket low msg in dash
dud you figure out the issue? Mine is a 13, drive it 1x a month and for past 2 years start/stop has never worked. get the same msg about start/stop deactivated in normal mode while city driving- hardly have any highway driving. Also did you have any engine misfires or other engine error msg? Thanks-
hey thanks for the infobut unfortunately im down here near sea level in San Diego and defrost is not on....
Old Oct 23, 2018 | 02:15 PM
cclcal's Avatar
it works sometimes, other times it doesnt. Exact same scenario, same street, etc. Makes no sense.
I just turn it off now.
Old Oct 24, 2018 | 11:00 PM
No solution I guess
I will get a new battery In, hope that will fix the issue. TBD until next week.
Old Nov 23, 2018 | 01:39 PM
Chupacabra's Avatar
Chupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond reputeChupacabra has a reputation beyond repute
Yeah, my Auto-Stop quit working sometime ago. I didn't miss it when coming to stops. It still worked when coasting and such. Culprit was a weak battery. Basically, I liked it this way.
Old Nov 23, 2018 | 06:44 PM
Pmorritt's Avatar
Pmorritt is just really nicePmorritt is just really nicePmorritt is just really nicePmorritt is just really nice
just because the battery shows 12v+ doesnt mean that it’s not weak. tested under load is whats important.
Old May 17, 2023 | 10:36 AM
mechatony11's Avatar
mechatony11 is infamous around these parts
I apologize for resurrecting this old thread. My vehicle experienced the same problem. It turned out that I had a battery issue. It's quite inconvenient if your battery voltage is low for this feature. If you Google "Engine Auto Start/Stop Not Working on YOUCANIC," you'll find an article that discusses frequent problems and possible solutions.
haodeon
Oct 31, 2020 08:50 PM
TeamJones1962
Bentley
Aug 5, 2020 11:50 AM
adnanm3
Oct 10, 2017 08:59 AM
solrac6262
Jun 18, 2016 09:49 AM
zzzx
Cayenne 955/957
Apr 19, 2012 06:46 PM
