Pink Fluid Leak Under Engine
So I am in my garage and notice a pink fluid puddle under the rear of my car (2015 Cab 4) with 17,000 miles. I believe this is the engine coolant and the leak is worsened by running the engine. I assume the pressure makes the leak worse. Probably a water pump or a gasket. I am bringing the car into the dealer for service and I am attaching a pic of the leak. Anyone else ever have this issue? Thanks
did you take to JD?
Still in service dept at Porsche Monmouth. They said its a pipe/tube that connects the water pump. Waiting for the part to arrive and hopefully that will fix it. I'll keep updating the post. I have to add that I always get top service and treatment from these guys. They provided me a loaner too.
If you see Pink fluid under the car then it means your water pump is done, you need a replacement. Don't know why P didn't do a recall on these.
they did change the design so you will get a newer one but some of those have failed to.
very common in 2017 and 2018 991.2s
Insist your dealer replace it or you may have a bigger problem
Chances are very good that was not necessary, but they wanted a warranty repair and the time.
wkp42
02-16-2018 08:22 AM
007 Vantage
02-19-2014 08:53 AM
NTIMD8
10-24-2012 07:17 AM
