993 Last generation normally aspirated aircooled Porsche 911. Community includes the C2, C2s, C4, Targa, C4s and cabriolet discussion.
NEWBIE 993 Problems already
Old Nov 25, 2009 | 05:23 AM
ABCar's Avatar
ABCar is infamous around these parts
Picked up my 96 993 yesterday and made the 700 mile drive home. Love the car, but....
1. Rotten, moldy burn the nostril smell from heater?
It reminds me of the same old Saab smell I used to get. I know the car has sat alot for the last couple years...could be animal dead? Anyone had this problem and have suggestions on cleaning out the system without removing the heater box or exchangers? Or maybe prob is somewhere else.
2. Here is the big one. Very stiff clutch. Once in a while it will even stick on the way back out and then kind of "pop" out the rest of the way. Someone mentioned flushing the hydraulic fluid but wonder if there is a problem with the throw out bearing or related?
3. Rear spoiler does not retract...always. Did a search and will begin fix but if you have suggestions or links, thanks for those!
4. Cruise not working.. Microswitch at pedals? where to begin?
5. Throttle sticks at 3000 rpms. Also found fix's in search but any comments welcomed!
btw, I had a 996tt for a few months but just sold it for this 993. Above problems aside, I love the car so much more than the 996tt and look forward to sharing my ownership experiences here instead. Feels like a "real" Porsche. (no harm meant to 996-ers! just my feeling)
Old Nov 25, 2009 | 09:09 AM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
Did you not get a PPI first?
1. Replace the cabin filters, & you may have to purchase a AC system cleaner like this one
http://www.detailersdomain.com/1zein...iacleaner.aspx
It will clean out any bacteria in the system.
2. That is SO NOT NORMAL. It might be a binding return spring on the pedal, but the push down should be easy. I would bleed the clutch & hope that works, if not it may be the throw out bearing, that is $$.
3. It never retracts? Does it move with the switch? The activator is under the dash on the passenger side, you should be able to hear it click when it goes up, & same when it goes down. It's a grey box, near the bottom. Make sure it plugged in all the way.
4. I hope this is not related to the clutch & AC system. Remove the floor mats & the wood pedal cover, make sure there isn't water & rust in there. You may have to spray some lube in the pedal area & make sure there is nothing obstructing anything. On a 96+ the throttle cable is not easy to get at, it's behind the air cleaner. You need to find what end it is binding on. This is also not a normal problem.
I seriously hope you don't have some bad water leaks & the pedal box is all messed up, causing the issues you have & the smell.
Old Nov 25, 2009 | 06:24 PM
w00zie's Avatar
w00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to beholdw00zie is a splendid one to behold
Had the same issue w/my AC. a new filter & cleaner the car smells 10000 times better
Also had the same issue w/the pedal, thankfully mine was a spring issue
I found myself a good (and trustworthy) experienced mechanic who specialized in 993's, if you can find one he (or she) will be worth their weight in gold
w
Old Nov 25, 2009 | 06:53 PM
ABCar's Avatar
Update. I sprayed some carb cleaner on the throttle linkage (for lack of proper name) in the engine compartment. The throttle, for now, does not stick and returns to normal idle all the time.
The smell seems better now too...maybe it just needs time and regular use to air out. I will change the filters though and make sure I am up to date on that.
When you say a new "cleaner" what do you mean? I know the cabin filter is in the trunk but what is the cleaner?
Finally you said you had a spring problem with the pedal...did you mean clutch or accel?
I would like to address any spring problem with the pedal...sounds easiest!
Thanks for all your responses...I will get this car sorted out!
Old Nov 25, 2009 | 07:04 PM
w00zie's Avatar
The A/C cleaner i used was 1Z Einszett Klima-Cleaner Air Conditioner Treatment
My spring issue was my clutch, wouldn't go up all the way, i would always have to pop it up w/my foot
w
Old Nov 25, 2009 | 08:38 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
how much are the filters, and is it something i can do, or need porsche to change out for me, once i buy it....? thanks in advance..
Old Nov 26, 2009 | 09:47 AM
There's 2, in the front trunk right under the windshield. They take about 10min to replace. Usually there around $40 for the pair.
Old Nov 26, 2009 | 10:31 AM
windydog's Avatar
windydog is infamous around these parts
check out pelican parts
Old Nov 30, 2009 | 09:52 PM
ABCar's Avatar
Im going to bleed the slave clyinder when I get the chance and see if that free's up the clutch. It seems a bit better with more use or maybe Im getting used to it.
Cruise works...I tried this on someones recommendation and it DID work.
Manually pull the clutch pedal towards you. The cruise worked after that.
Updates to come and relieved my 993 is beginning to shape up.
Old Dec 2, 2009 | 07:27 PM
DougM's Avatar
DougM is infamous around these parts
Check out http://p-car.com/ under the DIY section. Some of the issues you describe are in there.
Old Dec 2, 2009 | 08:19 PM
ABCar's Avatar
Thanks, Doug
Andy
Old Dec 3, 2009 | 08:43 AM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Welcome, no advice but, I sold my 996TT and bought an arena red 993 too. I loved the 996tt but, I have had so much more fun with this. Good luck and enjoy!
Hybrid
Jun 28, 2024 06:05 AM
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
jdbaker
Sep 19, 2015 10:34 AM
andbos
Sep 10, 2015 10:43 AM
arhim22
Sep 7, 2015 08:49 PM
