My PSM is going NUTS!
Hi all. Has anyone heard of PSM starting to go off for almost
no reason?
Today and recently in a gradual left-hand corner at typical
fast traffic speeds, my PSM kicks in, seeming to put the brakes
to the right front wheel. It drops the outside front as if my
spring had collapsed! In fact, part of my recent concern to do
corner weights was because that happened a couple of times
last week.
I talked to a Porsche mechanic informally about it, and he
suggested that I was either running tires of different diameters,
or interestingly, that the MAF unit was failing!
I just ran tape around both my front tires, and verified they were
the same...
no reason?
last week.
the same...
Joe,
Have them hook it up to the computer. The code will tell you what's wrong.
I was getting the PSM/ABS light and thought it was b/c of my chip when in reality it was just a bad MAF sensor.
He also mentioned low brake fluid levels as well as unbalanced tire pressures would trigger the lights.
Not just alignment but the actual specs of toe in, total toe, camber and straight ahead steer, then tire rolling diameters/pressure (may have been fine initially, but with some wear--especially asym. wear), then bad sensors. If your specs are close or just outside of range, a little change in the tires can trick PSM and if you turn off PSM, the car is just fine. The dealer should be able to figure it out.
Are the tires on each axle worn at the same rate? If you have replaced a flat on one corner, you now have tires running at different revs per mile. Have you varied tire sizes from OE? That could do it.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
randalldahme
Feb 19, 2016 03:56 PM
