Re-surfacing rotors?
Doing my first brake change on the TT and wanted to know pros/cons of resurfacing factory rotor. Left rear rotor has been grooved do to neglegence on my part. Bought the car with low brakes and got cought far from home one day and rotors have bes marked. Can this be done safely to factory rotors? Aside from buying new rotors, what are the best alternatives? Installing Mintex red pads if it makes a difference.
Also wanted to know difficulty level in removing rotors. Is it just the hex screws are is there more involved?
did this once to rotors that were warped/grooved and the results were horrible.
i dont know if it has to do with the fact that my rotors were really bad to beginwith.
did it since i had to go to the track the next day and as a last option since nothing else was available.
purchased new rotors right after.
In my exp. even if you could turn a cross drilled rotor which isn't recomended, once a rotor is warped by turning it true, you wind up removing so much material that the rotor is incredibly more prone to warping. As said before spring for new rotors.
I'm looking at $700+ to replace my GTO rotors...can't believe it!
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 28, 2015 10:48 AM
ECS Tuning - VW
Sep 28, 2015 03:19 PM
....lol.
