Grinding 3rd?
Grinding 3rd?
Was out in Mexico racing a buddy of mine tonight and everytime I would shift hard into third it would grind just ever so slightly, but it would go into gear and I would continue to accelerate.
I had my friend who is a tech at Porsche check out the car a week ago and he says I need some kind of clutch accumulator. Would this be the cause since the clutch is definetely feeling weird.
I am not sure if it is what is causing this feeling you are getting, but you can easily tell if the accumulator is bad. The clutch should go to the floor when the car is turned off with absolutely no resistance at all. If there is any resistance, the accumulator is probably bad.
The clutch does not go to the floor when the car is off. When the car turns off I can feel the clutch pedal loosen up and then its able to go to the floor.
Im getting this too...got it during one of my sprint races and just said **** this, im still going to beat the **** out of you...she listened...
Hahah good man!
M5_Forever
Southwest
Sep 21, 2015 11:36 PM
