Boost problem
Old Jan 12, 2008 | 07:33 AM
TwinT's Avatar
TwinT is infamous around these parts
Boost problem
It feels like my car is boosting less even though it is indicating the same amount on the display.
I recently had an ECU flash but and the difference was amazing, however my clutch needed replacing.
Now I have a LWFW and clutch fitted and recieved the car back it does not perform the same and it seems not too hold boost like it did before.
it says the boost is there but I can feel it is not.
I have not upgraded the DV's yet.
are the DV's the problem?
Old Jan 12, 2008 | 08:28 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
This issue is covered time and time again.
1) Could be a boost leak...Hose...DV.....Wastegate
2) Could be plugs..
3) ECU going into limp mode
4) Clutch could be slipping
Take the care in and get it checked. With out more info its hard to pin point.
Old Jan 12, 2008 | 09:09 AM
TwinT's Avatar
Hi kilrgt,
I have checked the ECU with Durametric and no fault codes. Clutch does not seem to be slipping, it was before the new clutch but not now.
it seems to be boosting in lower gears ok but having problem gaining/holding boost in higher gears.
The dealer replaced some hose clips when the clutch was completed and apparently checked all hoses.
I think I will buy some Bailey DV's and hopefully this will resolve the problem.
thanks
Lee
2) Could be plugs..
Old Jan 12, 2008 | 09:16 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
it might simply be that you are used to the power, it's your body telling you to put in bigger turbos
Old Jan 12, 2008 | 09:18 AM
kilrgt's Avatar
Befor the " ECU tune " what kind of booste were you making..I mean making not peaking.
Old Jan 12, 2008 | 09:19 AM
TwinT's Avatar
before was 0.6 or 0.7
now 1.2 to 1.3
K16 turbo car
Old Jan 12, 2008 | 09:21 AM
kilrgt's Avatar
If its hitting 1.3 Bar, its going into limp mode, What kind of tune do you have? K16 can not make that kind of boost.Time for a turbo upgrade !!
Old Jan 12, 2008 | 09:27 AM
TwinT's Avatar
I have a less aggressive file so I will upload that and see how I do.
I think I will upgrade the DV's anyway.
Thanks for your help.
out of interest how much can I get some k16/24's for?
Old Jan 12, 2008 | 09:45 AM
wross996TT's Avatar
You max out power on K16s about 1.0-1.1...so anything over that is just too much. You are also at the limit of the stock wastegates....contact Kevin @UMW for hybrid turbo prices.
Old Jan 12, 2008 | 09:52 AM
sharkster's Avatar
1.3 is wayyy too much for K16s. You're over-spinning them so have it turned down to 1.1 bar in the program at most.
Old Jan 12, 2008 | 10:16 AM
TwinT's Avatar
have just uploaded the more conservative map at 1.2 bar.
took her for a spin and it spikes at 1.2 but I am now regularly seeing 1.0. & 1.1
thanks again, will I have damaged my turbos? I saw a spike of 1.4 in 6th gear
Old Jan 12, 2008 | 10:19 AM
wross996TT's Avatar
Spikes are just that...there is debate on whether they really mean anything on the stock gage. If you actually are boosting that much surely your car will go into limp to protect itself. As far as the turbos go...you are probably OK.
Evan5469
Oct 29, 2015 06:39 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
nal991
Sep 11, 2015 09:05 AM
rsdub
Sep 10, 2015 03:30 PM
flewis763
Sep 10, 2015 01:08 PM
