Diverter Valve - which is best?
Old Feb 2, 2008 | 08:26 PM
tjj7ff's Avatar
tjj7ff is infamous around these parts
Which diverter valve would you recommend for an 03 TT with no upgrades? I think mine might be leaking a bit as I hear a high pitched air sound coming from the engine bay when getting on the throttle and the whoosh sound when lifting from the excess being blown off.
Old Feb 2, 2008 | 08:41 PM
DNugget991GT3's Avatar
my car has billet diverter valves
just curious (since i havent driven my car yet) , do you guys hear the diverter valves when you let off the gas ?
Old Feb 2, 2008 | 10:11 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I use the FVD Billet DV valve , its a great value and No I don't hear them when I let off the fuel...........then again I have strait pipes so I don't hear anything. Why are you replacing them are the stock ones coming apart? If its just to change I would nt bother until you have to, or until you start making more power.
Old Feb 2, 2008 | 10:24 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Bailey
Old Feb 2, 2008 | 10:35 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I have the forge ones with 90 degree angle,very solid...
Old Feb 2, 2008 | 11:05 PM
MGS996TT's Avatar
MGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to behold
Using Forge with UMW preset tension (shim washers).
As Dixie mentioned, make sure you get the one with 90deg angle.
Old Feb 3, 2008 | 03:45 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Agency Power single adjustable (and open to atmosphere). Love it.
Old Feb 3, 2008 | 10:33 AM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
I've got the EVOMS DV's and they work well. The vacuum line hookup has a 90 degree bend at the top which makes install much easier. You can get them in black or polished. I went with black so they don't stick out so much. When you install them, I would install a new F-hose while you have everything apart.
Old Feb 3, 2008 | 12:55 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
+1 to all that. The 90 degree connection is a must -- space is tight. Might as well do the silicone F-hose, since it's the same amount of work while you're doing the DVs. I would add that you should convert to the screw type hose clamps to replace the stock ones, to make sure you get a good seal with the new DVs and F-hose.
Old Feb 3, 2008 | 01:14 PM
oak's Avatar
oak
it's a job you want to do once. get the baileys and be done with it. mike @ awe board sponser is a distributor and has the correct version with all the correct fittings for the applications.
Old Feb 3, 2008 | 01:26 PM
fastoc996twint's Avatar
fastoc996twint is infamous around these parts
how hard is that setup to instal... price?.. any other necessary mods needed forthat set up?
Old Feb 3, 2008 | 01:31 PM
jimmer23's Avatar
Call Dan @ Vivid for pricing. No way for it to fit in stock location, so I tore out all of the hoses and the solenoid that were back there and just rigged a single BOV to the outlet on the Y-pipe using a 90deg silicone hose reducer. Works great. Have to reroute some vacuum lines and plug the port on the intake plenum where the f-pipe connected to. Not a big deal.
Old Feb 3, 2008 | 01:38 PM
How Do U Adjust?.. What Do U Base Yourself On? As Far As Stock/ Tuned Goes???
Old Feb 3, 2008 | 01:43 PM
jimmer23's Avatar
If you can hear it, it's working. If you're losing boost at WOT, you need to tighten it. If you don't hear it, or are getting boost spikes, you need to loosen the valve. Easy-peasy.
Old Feb 3, 2008 | 01:45 PM
oak's Avatar
oak
how much power does venting to the atmpshpere produce?
