Lug-Bolts for spacers
Old Mar 6, 2008 | 04:50 PM
heavychevy's Avatar
Where can I getem'? I tried performanceparts, but they said monday and I needem tommorrow. Procrastination is not your friend.
Old Mar 6, 2008 | 05:05 PM
DYL 911's Avatar
DYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to all
very odd to have gotten a set of spacers that didn't come with the longer lugs, unfortunately they are not readily available in most places. hope u find them soon
Old Mar 6, 2008 | 05:08 PM
heavychevy's Avatar
I had them all, two got stripped.
Old Mar 6, 2008 | 06:50 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
Did you try Tirerack?
Old Mar 6, 2008 | 07:41 PM
Turbo Fanatic's Avatar
Performance Products stocks them. the 60mm works for both 7 and 15 mm spacers and match the stock and silver finish wheels perfectly. $4.50 each.
Old Mar 6, 2008 | 07:54 PM
heavychevy's Avatar
I didnt think of them until after they were closed.
Worst comes to worst I'll just get stock lugs and take the spacers off for this weekend. And get the longer ones next week.
Unless I can find a stud conversion kit.
Old Mar 6, 2008 | 09:00 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
A cautionary note; I would suggest spacers with studs built into them. This way you can use the Porsche traditional lug nuts in anodized aluminum which are very light and readily available from a number or sources. Also it is so much easier to get wheels first mounted onto studs then trying to hold the #$%^! while you get a bolt piloted into place. Sorry for the problem heavychevy.
Old Mar 6, 2008 | 09:54 PM
heavychevy's Avatar
That sounds scary to me for some reason. How do these work? How do they attach to the hub?
Old Mar 6, 2008 | 09:57 PM
MGS996TT's Avatar
MGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to behold
Garey, why the cautionary note? Do you foresee a design flaw with non stud spacers?
Old Mar 6, 2008 | 11:52 PM
heavychevy's Avatar
Found these from summit racing. It's a grip from my house (1hr) but well worth the trip to pass tech. They are identical to the ones that come from H&R.
Boldgt
Mar 23, 2016 11:07 AM
djhill
Oct 29, 2015 07:04 PM
DYL 911
Oct 1, 2015 02:47 PM
Pcar991
Sep 29, 2015 05:20 AM
