Indicator Failure
Old Jun 1, 2008 | 10:50 AM
4G64T's Avatar
4G64T is infamous around these parts
Indicator Failure
Today, I go an Indicator Failure related to Oil Pressure. Prior to this I noticed that the the Oil Pressure gauge needle was moving up and down very erratically. The level of Oil is no problem. What could this be? It could be wiring as the road is very uneven here especially since I upgraded my suspension.
Old Jun 1, 2008 | 12:14 PM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
Sounds like the Oil Pressure Sender. They have been a problem here on the forum.
Old Jun 1, 2008 | 12:21 PM
liquidcool's Avatar
liquidcool is infamous around these parts
If I can chime in, the oil pressure sender unit has two terminals - one with variable resistance to indicate the needle's position. The other terminal is a yes/no you have pressure which drives the idiot light on the dash. If you're having trouble with both, it may be a real issue. Fingers crossed for you that it's just the sending unit which costs about $75 and maybe 1-2 hours labor to install.
Worst case would be oil pump failure but I'm told that's extremely unlikely - almost unheard of. Or could be the oil pressure release valves or something floating around in the oil that's gumming it up on occasion.
Fingers crossed for you that it's the simple cause of the sending unit!
Old Jun 1, 2008 | 08:21 PM
4G64T's Avatar
Thanks guys. It has to be the Oil pressure sender unit and the terminal that indicate the needle's position as the needle is moving eratically and the car is still running after driving home and the drive is about 20 miles.
Old Jun 6, 2008 | 02:15 AM
4G64T's Avatar
How easy is it to check the wiring? Can some give me the location of the Oil Sender unit as well as part number? Thanks in advance.
Old Jun 6, 2008 | 01:15 PM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
That just happened to me. Was the sending unit. Replaced under warranty.
Old Jun 6, 2008 | 01:57 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Could someone post a part number and perhaps a photo/howto?
TIA. I may have the same issue. I get an error.....but on turning the car off and running it, it went away. No amount of pushing the car triggers it..so I have to assume it is a bad or going bad sender.....
Do you have to dump the car's oil to do the switch?...etc.
JB
Old Jun 6, 2008 | 02:04 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
996.606.203.01
Old Jun 6, 2008 | 02:10 PM
Thank you!!!
JB
PV=nRT.
Sep 9, 2022 06:06 PM
adnanm3
Oct 25, 2016 08:38 AM
randalldahme
Feb 19, 2016 03:56 PM
DYL 911
Oct 1, 2015 02:47 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
