Clean your nose recently??
changing over to a full GT2 nose conversion for better cooling and down force (not a poser bolt on look alike!) and found clogged **** everywhere
the front radiator so bad I replaced it.
cleaned the sides.
some damage looked like fins bent from pressure washer so be careful.
radiator after condenser removed
realized that front bumper looked heavy so off it came
now matches the rear bumper off...
new and old front radiator top stock bottom GT2
cleaned the sides.
sorry the *** weighs toooooo much, muffler, bumper, wiper, lexan rear window
not a bad idea but with the supports still on not much weight is saved.
I am putting a screen mesh on this time
Good point, he's going to need a heck of a lot if the new rear wing is pushing down like I think it will.
if you look at your car the air comes in the front grille and is ducted UNDER the car look at the little vents, thus causing lift if anything.
the GT2 set up has larger radiator and it is canted for the air to flow through it (more cooling) and then out the top GT2 bumper grille and over the hood of the car giving downforce.
also the bumper I am putting on has a larger front CF splitter to compensate for the large 63 inch CF wing.
stuff getting painted now will post later.
thanks for reading....
