Dynapack Dyno?
Old Dec 1, 2008 | 02:19 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Question Dynapack Dyno?
The nearest 4WD Dyno to me has a Dynapack 6000 - where the wheels are removed and the dynos are attached to the axles
I currently know very little about dynos
Are these ok? Or should I find something else?
Old Dec 1, 2008 | 02:27 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Dynapacks are very high quality dyno's. They often read higher then other machines, so make sure you know what a stock car makes before trying to compare you results to others.
I also highly recommend disconnecting your drive shaft and dynoing RWD as all 4 wheels will spin independently and can damage your drivetrain.
Old Dec 1, 2008 | 02:44 PM
ant_8u's Avatar
How does this cause damage?
Porsche turbos are very rare around here, so I wouldn't really want someone trying to disconnect the front diff/drive shaft without prior experience - Is it an easy job or does it require some work and skill?
Would I be better looking from something else if I don't want to disconnect the front diff/ drive shaft?
Old Dec 1, 2008 | 02:48 PM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
How do you disconnect the drive shaft?
THANK YOU!
Old Dec 2, 2008 | 02:43 AM
ant_8u's Avatar
Can I just remove the prop shaft?
Old Dec 2, 2008 | 07:11 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
You simply remove the front diff. put it on dyno with PSM off.
Old Dec 2, 2008 | 08:34 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
You simply remove the driveshaft connecting the transmission to the front differential. No need to remove the actual front differential
Old Dec 2, 2008 | 09:20 PM
PorschePhd's Avatar
Remove the shaft before running on a dynapac, do not run in AWD.
Old Dec 3, 2008 | 10:52 AM
ttboost's Avatar
Is this because this dyno is actually like 4 little dyno's and all the wheels are NOT actually turning at the same rate? Maybe the left front is turning faster and burn up the diff?
Emre@Esmotor
Oct 19, 2015 12:06 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
